  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How do I deal with video like this:
    Complete name : J:\REC_0002\REC_00.TS
    Format : MPEG-TS
    File size : 2.00 GiB
    Duration : 40mn 53s
    Overall bit rate : 7 002 Kbps
    Video
    Menu ID : 28016 (0x6D70)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Codec ID : 2
    Duration : 40mn 52s
    Bit rate mode : Variable
    Bit rate : 5 557 Kbps
    Nominal bit rate : 15.0 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    ActiveFormatDescription : Letterbox 16:9 image
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.536
    Stream size : 1.59 GiB (79%)
    Audio #1
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 40mn 53s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Video delay : -170ms
    Stream size : 74.9 MiB (4%)
    Language : German
    Audio #2
    Format : MPEG Audio
    Codec ID : 3
    Duration : 40mn 53s
    Bit rate : 192 Kbps
    Video delay : -130ms
    Stream size : 56.2 MiB (3%)
    Audio #3
    Format : MPEG Audio
    Codec ID : 3
    Duration : 40mn 53s
    Bit rate : 192 Kbps
    Language : Multiple languages
    Audio #4
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 6
    Duration : 40mn 53s
    Bit rate : 448 Kbps
    Bit depth : 16 bits
    Video delay : -172ms
    Stream size : 131 MiB (6%)
    Language : German
    Menu
    Duration : 40mn 53s
    List : 1110 (0x456) (MPEG Video) / 1120 (0x460) (MPEG Audio, German) / 1121 (0x461) (MPEG Audio) / 1122
    I normally use AviDemux and take just one audio stream since most of what I record is OLD stuff...but this recording was done recently so the 5.1 audio is probably "real 5.1" so I'd like to keep it along with one of the other audio streams. I usually have to re-sync the audio in AviDemux(though the original TS file plays perfectly in VLC). How do I go about editing this, keeping in mind that I want two audio streams in my end result?
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    According ton your mediainfo log only audio track 4 is AC3 and it is stereo so not sure where the 5.1 is coming from? The file format looks as if it came from a Topfield? If you want to maintain the file format as TS with all the tracks them maybe SmartCutter would be the way to go? Otherwise demux with ProjectX and lay the audio track you want with the video in a mpeg editor like Vegas etc...
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You're right....this particular recording doesn't have 5.1.....silly me. I do recall recent TV series I've recorded that did have 5.1....my mistake.
    I did download ProjextX but found no .exe file anywhere.
    I'll look into smartcutter(?).
    Oct 2005
    666th portal
    projectx is a java program. use the included .jar file to launch.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Thanks!!!
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Oh and by the way.....ProjectX is freakin' brilliant.
