Hello, I have a problem with a .flv file I downloaded some time ago (not available anymore online). It's nearly 1GB large, should be around an hour in length, but only plays for 29 seconds in the beginning. MPC displays 28:11 as its duration, but can't seek beyond those first 29 secs.
The video file FLV Extract outputs is a ~7mb .264
Is there anything that can be done to repair this FLV file? Rebuilding it with avidemux crashes the program...
Thank you!
Here is the MediaInfo log:
Code:General Complete name : C:\65930.flv Format : Flash Video File size : 1 011 MiB Duration : 1h 7mn Overall bit rate : 2 101 Kbps Tagged date : UTC 2012-05-17 00:03:05 Tagging application : flvmeta 1.1-gb899474 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 7 Duration : 1h 7mn Bit rate : 1 773 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.047 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.171 Stream size : 6.25 MiB (1%) Writing library : x264 core 120 r2120 0c7dab9 Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=125 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=22.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 2 Codec ID/Hint : MP3 Duration : 1h 7mn Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Delay relative to video : 80ms Stream size : 462 KiB (0%)
	You could try remux with yamb or mymp4boxgui(open flv and make a mp4) or reconvert to some other format with xmedia recode, handbrake, etc.
 But I guess it will fail also. You coould then try video repair tool or www.mp4repair.org. But they aren't free.
	Thank you for trying to help out. Unfortunately, everything suggested failed one way or the other... :/
  Compress large FLV file to a smaller size FLV fileBy RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21
  Home video to flv - quality loss and file sizeBy Bain80 in forum Video ConversionReplies: 3Last Post: 20th Aug 2011, 20:08
  Help converting small size but large stream size asf video stream file?By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01
  FLV file with no video streamBy CSULB71 in forum Video ConversionReplies: 2Last Post: 13th Jul 2009, 23:37
  Is There a Practical File Size Limit For Streaming FLV?By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 10:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
