Results 1 to 21 of 21
  1. PSCO2007
    May 2010
    Southern Ca.
    Just bought this unit http://www.amazon.com/gp/product/B004HO58SO/ref=as_li_ss_tl?ie=UTF8&tag=herofide-20&li...SIN=B004HO58SO
    It scanned channels and plays fine.
    I want to use Media Center to record and the instructions say to open it and click "tasks."
    When I open Media Center, there are no choices for that.
    Also, since I don't have a network, is the included Ethernet necessary?
    Thanks,
    Paul
    Aug 2006
    If Media Center setup is complete, and the guide data download is finished, all you need to do to schedule a recording is click on the guide listing for the program you want to record and select "record" or "record series". You can also click the red dot control on the Live TV window and begin recording from that point on.
  3. PSCO2007
    May 2010
    Southern Ca.
    That's the problem.
    How do I set up the Media Center configuration?
    The tuner says I have to have it scan channels, but I don't see that choice.
  4. Yes, it works just as usually_quiet says. Did you go through the Digital Cable Adviser and then the digital cable setup?
  5. PSCO2007
    May 2010
    Southern Ca.
    This is all I see when I open Media Center - no choices for setup.
Name:	Media Ctr pic.jpg
    Aug 2006
    You don't need to run the digital cable adviser for the HD Homerun. The HD Homerun is for over-the-air ATSC and clear QAM. You only need to run the digital cable adviser for the HD Homerun Prime, SiliconDust's CableCARD tuner.
    Are you setting up for clear QAM or ATSC?
  7. PSCO2007
    May 2010
    Southern Ca.
    I set up for over the air channels on Hd homerun setup, but don't know how to scan channels using Media Ctr as the Hd Homerun says to do.
    Aug 2006
    Click on "Tasks", then "General" then "Windows Media Center Setup". At that point I would choose "Set Up TV Signal" to just add a new tuner, or if you are setting up Media Center for the first time, run the full Media Center setup (at the bottom of the list).
  9. PSCO2007
    May 2010
    Southern Ca.
    Media Ctr is not included in Windows 7 - have to pay for it?
  10. Windows Media Center is included in Win7 Home Premium and Ultimate. Not in Professional.
  11. PSCO2007
    May 2010
    Southern Ca.
    That's what I have -Windows 7 Pro.
    Can't believe it.
  12. Originally Posted by usually_quiet View Post
    You don't need to run the digital cable adviser for the HD Homerun... You only need to run the digital cable adviser for the HD Homerun Prime
    Ah, I only have the Prime.
  13. Originally Posted by Psco2007 View Post
    Then how does it connect to the computer? Maybe you need a crossover ethernet cable?
  14. PSCO2007
    May 2010
    Southern Ca.
    Media Center is indeed included in Windows 7 Pro- All I had to do was scroll down on the main page and go to Tv setup.
    All is working now.
  15. Originally Posted by Psco2007 View Post
    You're right. It was XP where Media Center wasn't included in the Pro version.
  16. PSCO2007
    May 2010
    Southern Ca.
    Thanks for your help.
    Aug 2006
    I remember Microsoft's features comparison page for the different Windows 7 editions originally showed Media Center as not included for Professional, but it was marked as included for Home Premium and Ultimate. (I only remember because it seemed strange, and I attributed the exclusion to the Pro edition being a business-oriented product.) The page now shows Media Center as included for all three of them. Perhaps the features comparison chart needed a correction, or perhaps Microsoft decided to include Media Center later on.
    The only version of XP with Media Center was Windows XP Media Center Edition 2005.
  18. Can't keep all these versions straight! Here's a table that shows Windows Vista only has Media Center on Home Premium and Ultimate versions:
    http://windows.microsoft.com/en-us/windows-vista/products/compare?T1=tab01
    Aug 2006
    Windows 8 won't include Media Center or built-in DVD playback capability for Windows Media Player in any editions. Users who want those features have to pay extra for them, and acquire them in a separate package. Only Windows 7 Pro will support the package, so those who have plain Windows 8, will need to pay for an upgrade to Pro as well. This decision will likely discourage many of those currently using Media Center in their Windows 7 machine from upgrading, especially anyone with a CableCARD tuner installed. There are alternative Media Centers and players, but Windows Media Center is the only software that will work with a CableCARD tuner.
    http://news.cnet.com/8301-10805_3-57427979-75/microsoft-angers-users-by-cutting-media-...-of-windows-8/
    http://blogs.msdn.com/b/b8/archive/2012/05/03/making-windows-media-center-available-in...windows-8.aspx
    Apr 2001
    I'm not sure what variant of Win7 pro you're referring to, but my system is running Win7 Pro 64-bit, and WMC7 is most definitely on there. i think you probably meant it's not available on the Basic (?) or Starter (?) editions. But it's definitely available on everything else.
    Let's hope Microsoft rethinks the entire WMC8-as-add-on angle before Win8 comes out.
  21. Originally Posted by CubDukat View Post
    If you read the later posts you'll see that we've already established that WMC is included in Win7 Pro. It was Vista Pro that didn't include WMC. Early Microsoft documents may have indicated that Win7 Pro didn't include WMC -- I don't remember for sure.
