Whats wrong with Sony Vegas?
I have a 3 hour video which needs to fit in one DVD. I calculated everything with Avidemux and came with the results 2,9 MB/s video and 192 kb/s audio.
So I rendered it to MPEG2 with cbr 2,9 MB/s video and cbr 192 kb/s audio.
With this settings it should fit in one DVD, however the result was 5,15 GB.
I looked with mediainfo and the video bitrate was 3,7 MB/s !
I spended the whole evening rendering that video, and this are the results. 2 questions:
Why?
How can I force it to have a certain bitrate?
I use Sony Vegas 10 btw
Results 1 to 15 of 15
The flag once raised will never fall!
Yes you could render to lossless avi and plug it into HCenc, but why bother, just use Vegas's mainconcept encoder which is just as good.
Yes, the MPEg2 results from Vegas were always good. But if I can't solve this, I will use HCenc.
Yes, I had put constant bitrate to 2,9 MB/s. And audio is MPEG layer 2 192 kb/s
Today I tried to use variable bitrate, because Vegas ignored the cbr.
And I got same results, 3,7 MB/s, while I put max 2,9Mb/s and average 2,5 MB/s on video settings.
I use the DVD PAL template, but with my own bitrates.
Is this a bug? I will try then HCenc or on older Vegas version.The flag once raised will never fall! -
The original source file is DV avi. These are the details of MPEG2 exported file
General
Complete name : C:\Users\-\Desktop\Back to School.mpg
Format : MPEG-PS
File size : 4.85 GiB
Duration : 3h 4mn
Overall bit rate : 3 758 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 3h 4mn
Bit rate mode : Variable
Bit rate : 3 491 Kbps
Maximum bit rate : 2 900 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.337
Stream size : 4.51 GiB (93%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 3h 4mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 254 MiB (5%)
Menu
something's not right with your vegas mpeg encoder. you might try uninstalling and reinstalling vegas. i did 8 dvd spec mpeg-2 encodes with a setting of average 4200 max 9500 for a recent project and the most one was off came in at 4205.
General
Complete name : W:\vegas\YMCA_JUNE_2012_tape2a_merged_cut.m2v
Format : MPEG Video
File size : 783 MiB
Duration : 26mn 2s
Overall bit rate : 4 205 Kbps
Video
Format : MPEG Video
Format settings, GOP : M=3, N=15
Duration : 26mn 2s
Bit rate : 4 205 Kbps
Maximum bit rate : 9 500 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.406
Stream size : 783 MiB (100%)--
i use pro11 here, 10 never thrilled me, 9 was ok. i used 6 for the longest time. if you can get it 11 works nicely.
There was an update that fixed that. Apparently yours is bootleg. You don't want to update it. Hahaha. There's no way a registered Vegas user would not receive a notification of available updates. I know, I've been a Vegas user for years.
If that were a trial you're using, it would be the latest build. Hahahaha. Busted.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
AviSubDetector picks up everything on line
By kpic in forum SubtitleReplies: 0Last Post: 26th May 2008, 08:45 -
Warner Bros. Picks Blu-Ray Over HD-DVD
By David K in forum Latest Video NewsReplies: 1Last Post: 5th Jan 2008, 15:13
