Hello!
I posted my solution on one forum in my country and nobody said it doesn't work, yet, so I'll try with wider audience.
I see there are many threads asking for help with no sound after converting to DVD-Video format with WinAvi.
I had the same problem and after a few days of different tries, I fixed the problem and the solution works fine on my computer.
I have WinAvi 9.0 installed.
These codecs are necessary for sure:
Haali Media Splitter
ffd show
I also have installed (not sure if necessary)
CCCP Codec Pack
VobSub
You may also need some other codecs for some conversions (like RealMedia codecs for converting from .rmvb)
Here is my solution:
1. Select "DVD" as Output Format.
2. Click "Advanced" next to it.
3. Make sure that in Audio Setting, "Enabled DirectAC3" is checked and "Encode Mode" is AC3.
4. Go to "DShow Decoder" on left-side menu and select "Audio Decoder" options.
5. Change used codec to "ffdshow" where possible, at least in "ac3".
6. Click OK.
7. DONE! Convert.
During conversion, I had ffdshow, Haali Media Splitter and VobSub codecs working for sure (had their icons on "start" bar).
Please let me know if it works for you.
Feel free to ask for additional details if you need any.
Hope it works for you all, too!
Nobody uses this software here. You are wasting your time and $50.
I am aware that there are many better programs.
Still, if I had some idea to fix this problem, I thought it would be nice to share it. Isn't it?
Maybe people who already paid this 50$ or just don't want to try other programs for some reason may have a good use of this solution.
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 18:17 -
help please, no sound when I've converted with winavi
By loadabull in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 03:57 -
WinAvi converts with No Sound
By Yanez in forum Video ConversionReplies: 5Last Post: 12th Sep 2008, 20:12 -
Audio Sync Problem using WinAvi
By BonnieW88 in forum Video ConversionReplies: 14Last Post: 14th Dec 2007, 11:33 -
winAVI video converter - problem with audio
By mahdlo in forum AudioReplies: 6Last Post: 5th Oct 2007, 00:39
