    Jul 2012
    Canada
    Hello,
    I just installed ffmpegX and the required binaries, I got no errors, everything seems to be installed correctly. But when I try to convert something, the ffmpegX Progress window appears, and half a second later, I get the "DING!" and a tiny file with maybe the first frame in it.
    Any idea what I'm doing wrong?
    Thanks!
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Please post the Process Information log, which is accessible by clicking the blue "i" in the ffmpegX Progress window.
    This log should hold information on what went wrong.
    Jul 2012
    Canada
    Thanks! Here you are:
    Encoding started on Mon Jul 9 10:53:25 PDT 2012
    MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
    Mac OSX static build for ffmpegX
    CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 6)
    CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
    FIXME:Hardenabling SSE and SSE2 without detection
    success: format: 0 data: 0x0 - 0xb3e3b9f
    Quicktime/MOV file format detected.
    VIDEO: [avc1] 720x404 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:7 fourcc:0x31637661 size:720x404 fps:23.98 ftime:=0.0417
    Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
    AUDIO: 48000 Hz, 2 ch, s16le, 127.7 kbit/8.31% (ratio: 15957->192000)
    Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=720 h=404]
    MP3 audio selected
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
    Forcing output fourcc to 58564944 [DIVX]
    [h264 @ 0x878f8c]reference picture missing during reorder
    [h264 @ 0x878f8c]abs_diff_pic_num overflow
    [h264 @ 0x878f8c]decode_slice_header error
    VDec: vo config request - 720 x 404 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
    [h264 @ 0x878f8c]concealing 1170 DC, 1170 AC, 1170 MV errors
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (720x404 fourcc=58564944 [DIVX])
    Writing header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    Writing header...
    1 duplicate frame(s)!
    Skipping frame!
    [h264 @ 0x878f8c]illegal short term buffer state detected
    Skipping frame!
    h264.c:4128: failed assertion `h->long_ref_count + h->short_ref_count <= h->sps.ref_frame_count'
    /bin/sh: line 1: 10992 Abort trap '/Library/Application Support/ffmpegX/mencoder' /Volumes/LaCie/MOVIES-laCie\ II/TV/Girls/Girls.S01E08.HDTV.x264-ASAP.mp4 -oac mp3lame -lameopts cbr:br=128:vol=0 -srate 48000 -aid 1 -ovc lavc -sws 0 -lavcopts threads=2:vcodec=mpeg4:vbitrate=940:keyint=240:vqm in=2:vqmax=15 -ofps 23.976 -vop scale=720:404 -noodml -ffourcc DIVX -o /Volumes/LaCie/MOVIES-laCie\ II/TV/Girls/Girls.S01E08.HDTV.x264-ASAP.mp4.ff.avi
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Unfortunately, it seems that your video has some properties that are not supported by the current version of ffmpegX.
    Jul 2012
    Canada
    Good to know, thanks! I'll keep an eye out for newer versions.
