Results 1 to 10 of 10
Buy the movie and rip from it ...or I'm pretty you will find the subs on some subtitle site in srt text format.
It is highly unlikely that this is protection. Many groups that make videos available put some kind of logo on the video but this is not meant to stop you from getting the subtitles. Subtitles may have different fonts and sometimes VobSub needs help. This all sounds normal to me.
Yeah, sounds like normal over-compression difficulties.
Scott -
Such as
http://www.opensubtitles.org/en/search/imdbid-1567609/sublanguageid-eng
where they have 14 versions to choose from.
I look at the preview to screen out the ones that are obvious crap and try a few of the rest.
If I need to resync, I use Subtitle Workshop, it's pretty simple if you read the manual.
Unless you need Hebrew, in which case: http://www.opensubtitles.org/en/subtitles/4594895/get-the-gringo-he -
forget to mention something. the subs in Hebrew language.
so right now they are the only ones. on the internet
and the group who made them release them on purpose as IDX (I dont know the reason). -
Did you bother to read my post? I linked Hebrew subs in SRT.
Is there a problem with those?
Anyway, I doubt your IDX SUBS were made to thwart you.
At worst it would take someone a couple of hours to correct the OCR by hand, or start with an English SRT and feed it into Google translate and tidy it up -- automatic translation is not the most fluent, but a good start. -
SUB/IDX format is straight from ripping and does not require OCR (Optical Character Recognition) so it's a very fast way to get the subs. Unfortunately SUB/IDX format is very inconvenient to do anything with except to display (with certain software and hardware players). So they are giving you SUB/IDX because it requires the least amount of work for them to get them off the disc.
Problem On Subtitle SUB/IDX format.
By ashkan_vpm2 in forum SubtitleReplies: 8Last Post: 6th Dec 2010, 00:22 -
Only .idx subtitle supplied
By saymell in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 01:17 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 12:25 -
How can I find the FPS of my Sub/Idx subtitle?
By reza_17173 in forum SubtitleReplies: 2Last Post: 7th Mar 2009, 09:47 -
about idx subtitle
By sg999 in forum SubtitleReplies: 4Last Post: 5th Nov 2008, 03:25
