Hello. This is my first post here, and I joined for the reason that I need major help with my capture card.
I have a Dazzle DVC100 that I recieved 2 Xmas ago. I have since lost the disc/instructions and have been left with the actual card left alone.
Ive tried in the past, but I cant seem to get it to work. Those damn YouTube tutorials are too confusing for me, and I really want to use my card.
I also need recomendations on programs that are available, and they must be free.
I want to record my Playstation 3 gameplay and upload it to YouTube. Some games I will be filming are Skyrim, Call Of Duty, Mass Effect 3, and GTA5 when it releases.
I would like to record using the AV components, but play using the HDMI cable. Also, I will need to have it so both game sound and my microphone sound be recorded.
I know it sounds like alot, but please help me.
You didn't say what operating system you're using. Doesn't the Dazzle/Pinnacle support site list any driver downloads?
It's been years since I had a Dazzle card and I don't play games. All I can tell you is that in the past that Dazzle made it very difficult to download their software without the disc (ATI is the same). You may have to buy a replacement CD.
This is not a high quality card so please do not have unrealistic expectations as to what it can do. It can only record in DVD quality and it apparently uses composite video only. You will NOT be able to record in high definition with this card. -
Forget about using HDMI for playing the game and using any of the console's analog A/V connection to record. Game consoles can't produce a signal for the HDMI port and the A/V port at the same time.
You would need a powered HDMI splitter and powered HDMI to composite/S-video, plus stereo audio converter to have both types of output at once. I suspect that would cost more than you want to pay, and wouldn't give you the quality you want.
You need to use composite or S-video plus stereo audio for both the TV and the Dazzle. That is what most of the YouTube videos are about.
It doesn't look like you can afford the the alternative, getting a different capture device, so you can use an HD connection for the TV TV. Even then HDMI is problematic. A component video capture device with an internal splitter, like the Hauppauge HD-PVR, works best with a PS3 because the PS3 places HDCP encryption on HDMI.
[Edit]HDMI capture devices are not allowed to record HDCP protected video. (The HDMI license requires that.) Some people find ways around it, but it is simper to use component video for capture instead. The captured video is still very good quality.Last edited by usually_quiet; 9th Jul 2012 at 10:40.
Advice needed for an Xbox 360 capture card.
By Bonno in forum CapturingReplies: 2Last Post: 23rd Oct 2010, 16:15 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Multiple DV source Capture card/box help/advice needed please
By OdubruS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Dec 2007, 11:08 -
Specific capture card needed... but I don't know which one
By jamnmon66 in forum CapturingReplies: 3Last Post: 7th Oct 2007, 18:15 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum CapturingReplies: 11Last Post: 5th Oct 2007, 04:31
