This thread is a continuation of this "old" thread: https://forum.videohelp.com/threads/53274-Ok-guys-DTS-conversion-challenge-with-FACTORY-DTS-DISCS-!!
PLZ, if you're going to respond do NOT make any comments in the old thread. I shared the link as reference to subject matter ONLY.
As a film fan I have a small collection which includes some DTS Cinema Audio CD-roms. For those who don't know, these cd-rom discs contain movie audio designed for theater presentations by DTS....they are NOT related to home theater versions of DTS...the 2 are completely different animals.
The file format on the discs I have is .aue. The previous DTS cd-rom audio was in .aud format which is already accessible. The .aue format is not at this point unless you own a DTS cinema processor.....there is no public software or open source solution that I know of.
Can anyone help me out with this?
Thanks for taking the time to read and thanks in advance if you decide to respond.
Cheers!!!!
Closed Thread
Mediainfo gave me this.....
General
Count : 279
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : Wave: 58.0 Bytes
Count of audio streams : 1
Audio_Format_List : PCM
Audio_Format_WithHint_List : PCM
Audio codecs : PCM
Complete name : C:\Documents and Settings\RELIANT\Local Settings\Application Data\Microsoft\CD Burning\DTS\New Microsoft Wave Sound Format.wav
Folder name : C:\Documents and Settings\RELIANT\Local Settings\Application Data\Microsoft\CD Burning\DTS
File name : New Microsoft Wave Sound Format
File extension : wav
Format : Wave
Format : Wave
Format/Extensions usually used : wav
Commercial name : Wave
Internet media type : audio/vnd.wave
Codec : Wave
Codec : Wave
Codec/Extensions usually used : wav
File size : 58
File size : 58.0 Bytes
File size : 58 Bytes
File size : 58.00 Bytes
Duration : 0
Duration : 00:00:00.000
File creation date : UTC 2012-07-10 04:07:34.796
File creation date (local) : 2012-07-09 23:07:34.796
File last modification date : UTC 2012-07-10 04:07:34.843
File last modification date (local) : 2012-07-09 23:07:34.843
Audio
Count : 217
Kind of stream : Audio
Inform : 176.4 Kbps, 22.05 KHz, 8 bits, 1 channel, PCM
Format : PCM
Commercial name : PCM
Format settings, Endianness : Little
Codec ID : 1
Codec ID/Url : http://www.microsoft.com/windows/
Codec : 1
Codec : PCM
Codec/Family : PCM
Codec/Info : Microsoft PCM
Codec/Url : http://www.microsoft.com/windows/
Codec/CC : 1
Duration : 0
Bit rate : 176400
Bit rate : 176.4 Kbps
Channel(s) : 1
Channel(s) : 1 channel
Sampling rate : 22050
Sampling rate : 22.05 KHz
Resolution : 8
Resolution : 8 bits
Bit depth : 8
Bit depth : 8 bits
Stream size : 0
Stream size : 0.00 Byte (0%)
Stream size : Byte0
Stream size : 0.0 Byte
Stream size : 0.000 Byte
Proportion of this stream : 0.00000Last edited by JetrellFo69; 10th Jul 2012 at 12:29.
You don't have the right to decide to create a new thread just because you disagree with what a moderator did with your old one. It will likely just be a short time before this is closed.
My previous advice still stands - you're asking for advice that very likely nobody here can help you with for a variety of reasons. Probably 99% of our members have never even seen such discs. Also, the very few who know something about them may be forbidden by NDAs to talk about it here.
You seem to have this false belief that the information you seek is with 100% certainty here, but the moderators have somehow screwed you out of getting a response. Trust me - if anybody here could really help you, the old thread would have gotten a response.
DTS to AC3 audio conversion (using MP4Tools on a Mac) issue/problem
By SimonSimon in forum AudioReplies: 1Last Post: 1st Sep 2011, 05:41 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
Hi Folks, First post, getting 0 K Mov to FLV conversion...
By dainis in forum ffmpegX general discussionReplies: 4Last Post: 28th Oct 2009, 05:16 -
Saving Unreadable DVD's Part Deux
By hitechluddite in forum Authoring (DVD)Replies: 21Last Post: 14th May 2009, 10:51 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
