Hello, Every one.
I've a problem while merging 2 h264/mp4 files width the same parameters except length.
I'm merging by "mp4box -cat ..." command. After that video players behave are strage:
if I drag time slider closer to the end of file it reset to restart the video and
some time, players are showing incorrect video file length.
Input file sample parameters:
* Movie Info *
Timescale 90000 - Duration 00:15:00.214
Fragmented File no - 2 track(s)
File suitable for progressive download (moov before mdat)
File Brand mp42 - version 0
Created: GMT Thu Jun 7 23:31:52 2012
File has root IOD (9 bytes)
Scene PL 0xff - Graphics PL 0xff - OD PL 0xff
Visual PL: ISO Reserved Profile (0x7f)
Audio PL: High Quality Audio Profile @ Level 2 (0x0f)
No streams included in root OD
iTunes Info:
Encoder Software: HandBrake 0.9.6 2012022800
Track # 1 Info - TrackID 1 - TimeScale 90000 - Duration 00:14:59.858
Media Info: Language "Undetermined" - Type "vide:avc1" - 21576 samples
Visual Track layout: x=0 y=0 width=853 height=480
MPEG-4 Config: Visual Stream - ObjectTypeIndication 0x21
AVC/H264 Video - Visual Size 864 x 480
AVC Info: 1 SPS - 1 PPS - Profile Main @ Level 3
NAL Unit length bits: 32
Pixel Aspect Ratio 80:81 - Indicated track size 853 x 480
Self-synchronized
Track # 2 Info - TrackID 2 - TimeScale 44100 - Duration 00:15:00.214
Media Info: Language "English" - Type "soun:mp4a" - 38769 samples
MPEG-4 Config: Audio Stream - ObjectTypeIndication 0x40
MPEG-4 Audio MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 44100
Synchronized on stream 1
Output:
* Movie Info *
Timescale 90000 - Duration 00:29:24.136
Fragmented File no - 3 track(s)
File Brand isom - version 1
Created: GMT Thu Jun 28 19:40:39 2012
Visual PL: AVC/H264 Profile (0x15)
Audio PL: AAC Profile @ Level 2 (0x29)
Track # 1 Info - TrackID 1 - TimeScale 90000 - Duration 00:19:36.968
Media Info: Language "Undetermined" - Type "vide:avc1" - 28219 samples
Visual Track layout: x=0 y=0 width=1024 height=576
AVC/H264 Video - Visual Size 1024 x 576
AVC Info: 1 SPS - 1 PPS - Profile Main @ Level 3.1
Pixel Aspect Ratio 1:1 - Indicated track size 1024 x 576
Self-synchronized
Track # 2 Info - TrackID 2 - TimeScale 44100 - Duration 00:29:24.136
Media Info: Language "English" - Type "soun:mp4a" - 75975 samples
Track # 3 Info - TrackID 3 - TimeScale 90000 - Duration 00:09:46.503
Media Info: Language "Undetermined" - Type "vide:avc1" - 14062 samples
Visual Track layout: x=0 y=0 width=1280 height=720
AVC/H264 Video - Visual Size 1280 x 720
Pixel Aspect Ratio 1:1 - Indicated track size 1280 x 720
And I do not understand, why in output file I have 2-video tracks?
Results 1 to 1 of 1
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
Merging and converting H.264 mp4 HD files from Samsung HMX-H204?
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Jun 2011, 06:41 -
Problems playing recorded .mp4 files
By dhr3 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 13:17 -
Audio Sync Problems With MP4 Files
By EmeraldTwilight in forum MacReplies: 4Last Post: 17th Nov 2008, 10:17 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 09:50
