Results 1 to 12 of 12
  1. please accept my apologies as a naive non expert with my first post........
    i have a large Video file on my PC and want to transfer onto a dvd disc/s(europe area 2) so i can delete and free up space.
    however i cannot seem to get my head around exactly how to do this ?
    The file is a .avi and is called HDTV.XviD-AFG.it is 1'188'335 kb.
    The software i am using is windows dvd maker (also imagburn and BurnAware Free.)
    on windows dvd maker i get a mesage saying insufficient space on disc which i understand.
    however id does not offer me any other option ie to spread across more than one dvd disc.
    Any advise as to how i go about doing this on my Existing or or any other (preferrably free) software would be greatly appreciated.
    Many thanks
    0
    Report
    MultiQuote
    Quote Reply
    Add Reply
    Edit
    Any advise as to how i go about doing this on my Burnaware Free or any other (preferrably free) software would be greatly appreciated.
    Many thanks
    Use avstodvd or dvd flick or convertxtodvd instead.
  3. Member Cornucopia's Avatar
    No, if you are just storing/archiving, then put the file in a zip/rar (in uncompressed "archive" mode) using segmented/disc-spanning, or use hjsplit. Then burn the dvd-sized split segments in Imgburn.
  4. Originally Posted by Cornucopia View Post
    But why would he be using DVD Maker if he didn't want to make a DVD playable in a DVD player? The 'insufficient space' message is unrelated to what he wants to do, and is typical DVD Maker idiocy. I'm with Baldrick. If he wants to make a playable DVD, try Avs2DVD.
    Admittedly, though, it's not entirely clear what he wants to do.
  5. many thanks for all the responses so quickly and apologies for not making myself clear.
    i have a couple of four hour plus video files (tv football programmes) which i want to strip off my pc. i want to save on to dvd disc/s so i can play on my dvd player here in uk.
  6. guys
    my aplogies for asking for more help but i am out of my depth a little here !
    i have now downloaded avstodvd including the haali media splitter.
    my first avi file is 4hrs 20 mins so i am assuming first i will have to split the avi file into 3 separate files - presumably on haali?
    my challenge is that having opened haali i cannot work out what to do next ie how to split the file into 3 ?
    any guidence here would be greatly appreciated.
    thanks
    Mar 2008
    Split the file into two using Virtualdub using this procedure:
    http://www.afterdawn.com/guides/archive/cut_avi_with_virtualdub.cfm
    Then encode each piece separately in AVStoDVD.
  8. Originally Posted by borischelski View Post
    my first avi file is 4hrs 20 mins so i am assuming first i will have to split the avi file into 3 separate files...
    Well, you don't have to split it up, but the final quality will be better if you do.
  9. Member Cornucopia's Avatar
    Ok, now I see. On your first post, your reasoning just was "so I can free up disc space", which would allow for just data splitting and burning onto data discs.
    On you 2nd post, you said "so I can play on my DVD player". That is a horse of a different color.
    Now, I'm in agreement with manono and Baldrick (& davenext's procedure) - AVS2DVD is a good start. Win DVD Maker is NOT what you want to use.
  10. Dear Friends
    Many thanks for all your help. I am nearly there having succeeded in splitting then burnt the first of the big files onto 2 dvds.
    However i am struggling with the larger 4 hrs 30 min file and wonder if i could ask for one final piece of help ?
    I can split it in 2 but when iu try to burn the second half the message on avs2dvd is says not enough space. Therefore i need to burn onto 3 dvd
    The virtual dub instructions describe how to split on first and second parts. My question is how do i apply these instructions to split a file into 3 segments ?
    Any final help greatly appreciated.
    best
  11. Originally Posted by borischelski View Post
    I can split it in 2 but when i try to burn the second half the message on avs2dvd is says not enough space.
    Then you're doing something wrong. If you're trying to burn to a DVD-5 (4.7 GB), then make sure the bitrate chosen isn't too high for that size. That is, rather than splitting the AVI yet again, lower the average bitrate (unless the average bitrate is chosen based on the DVD-5 size, in which case it can't be changed). And make sure the minimum bitrate (called 'lower bitrate level' or 'video lower avg bitrate') isn't too high. Set it at 250 maybe.
    Mar 2008
    I think AVstoDVD may be talking about HDD space.
