When I load a project into Windows live Moviemaker and play it I get no video only Audio.
What can I do to see/edit the video?
Here are the MP4 details
General
Complete name : D:\My Video's\July 32012\GOPR0011.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 80.9 MiB
Duration : 44s 611ms
Overall bit rate : 15.2 Mbps
Encoded date : UTC 2011-01-31 21:11:52
Tagged date : UTC 2011-01-31 21:11:52
AMBA :
Video
Format : AVC
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=15
Codec ID : avc1
Bit rate mode : Constant
Bit rate : 15.1 Mbps
Nominal bit rate : 49.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.242
Stream size : 80.1 MiB (99%)
Title : GoPro AVC
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 44s 608ms
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 697 KiB (1%)
Title : GoPro AAC
Language : English
Can you play the mp4 in windows movie player without problems?
YOu could try convert it to avi with mp4camtoavi and try in moviemaker. -
Yes I can Play/view The MP4 in Media Player
Just converted the mp4 to AVI and it still wont display video.. I get Audio but no video
Windows Live Mail question
By Moontrash in forum ComputerReplies: 3Last Post: 3rd Jan 2012, 13:16 -
My New WD TV Live having audio issues with M2ts files
By jbitakis in forum Media Center PC / MediaCentersReplies: 8Last Post: 7th Dec 2011, 19:06 -
Webcam live feed wrapped in AVI or MP4
By halogen in forum Video Streaming DownloadingReplies: 1Last Post: 1st Jun 2011, 20:55 -
Editing Sony DCR DVD 405 Recording/Files in Windows Moviemaker and iMovie
By pmblr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Nov 2010, 15:19 -
I lost quality with windows moviemaker-HELP
By croarta in forum EditingReplies: 5Last Post: 26th Sep 2010, 13:37
