I want to make a XSVCD2: A XSVCD2 is a XVCD created with a mpeg2 clip that you only change the file header for mpeg 1 file by multiplexing the file in TMPGenc.... You can then burn it in Nero as a VCD and it plays fine on my DVD. The reason why I do that is because my DVD cannot play SVCD...
The problem i have is that I really want to use Ulead DVD movie factory to create my VCD. But DVDMF doesnt accept my file as a VCD compliant file.
Is there another software I can use to change the file format header?
PLEASE HELP ME!
Results 1 to 1 of 1
Question about how to modify exe file
By jimdagys in forum ComputerReplies: 9Last Post: 29th Oct 2011, 17:59 -
Trying to modify .VOB file - why didn't this work?
By brassplyer in forum Authoring (DVD)Replies: 8Last Post: 7th Feb 2011, 22:03 -
can you edit the header of an mpg file
By lmwashere in forum EditingReplies: 9Last Post: 13th Nov 2009, 21:07 -
AC-3 file header errors?
By DRP in forum AudioReplies: 1Last Post: 27th Jun 2009, 23:24 -
How to modify AAC header?
By Emeritus in forum AudioReplies: 0Last Post: 12th Jan 2009, 08:17
