i try to rip dvd to audio file , using PgcDemux
but the audio files is .mpa instead of .ac3
do i have any mistake config
or suggest me please how to convert MPA to AC3 with lossless
What? If there's no AC3 in there, use what it gives you. Or convert it to AC3 yourself. Is there any reason you can't use the MPA audio? It's not going to get any better by converting it.
It can't give you what doesn't exist. Don't blame it on PGCDemux.PgcDemux cannot rip to ac3 file -
Thanks manono
Everyone tell me that this program will give me AC3 audio
But when I finished ripping , I recieve MPA audio that I don't need it
I just want to know Can I select the audio file which I prefer (AC3) from this program? -
Pgcdemux just extracts video and audio streams from a vob structure (like a dvd)
So after using the program you end up whith a video stream and 1 or multiple audio streams just like they where in the vob files.
In the case that the vob files only contains mpeg audio (mpa) you get a mpa file.
if you need a ac3 file you have to convert it but i agree with manono that's not going to improve anything. -
There doesn't seem to be any AC3 audio on your DVD. MPA audio is legal for PAL DVDs, but this must be an old disc as I haven't heard of MPA being used on any PAL DVDs since maybe 2005 or so. You cannot extract AC3 because it's not there on your DVD. You will have to convert the MPA to AC3 yourself.
If you don't understand what I said, we can't help you.
Issues demuxing VOB w\PGCDemux & VOBEdit
By kpic in forum DVD RippingReplies: 15Last Post: 2nd Oct 2012, 04:39 -
With PgcDemux demuxed subtitles can't be added to mkvmerge
By Julian_evil in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2011, 01:19 -
strange timing issues ripping dvd with pgcDemux
By ryoaska1 in forum DVD RippingReplies: 4Last Post: 26th May 2011, 23:22 -
PGCDemux/DGIndex audio delay report -- how to proceed?
By Gew in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2011, 04:22 -
VOB demuxer: PGCDemux or VOBEdit ?
By gabier in forum Video ConversionReplies: 4Last Post: 2nd Dec 2007, 10:01
