Results 1 to 26 of 26
  1. Hi guys,
    I have a Sony HDR-HC1E and am trying to capture using Premiere Pro CS6. For some reason it is capturing the file into an MP3, which is unreadable and no video is contained. I have checked all my settings, capturing in HDV, Project settings etc. Capturing into DV works fine. The only thing that concerns me is that my camera is showing as 'HDVin' rather than 'HDVout'. I've seen a few others have had this problem, yet there doesn't seem to be any definitive answer on how to fix it.
    And just for the record, capturing used to work fine!
  2. Just to add - it captures fine in DV which is now what I have resorted to. Would still like to know why I cant capture in HDV though!
  3. Is it capturing mp3 or mp2? mp3 would be really unusual.
    Check your camera settings. Based on your symptoms, be sure 1) you are outputting HDV -- not auto, and 2) that you have shot HDV and not DV in the first place.
  4. It is capturing MP3 (into a massive file). I have shot HDV 1080i, and as far as I can tell - I am outputting HDV. Premiere Pro *usually* doesn't even allow for a capture to begin if you're set on the wrong mode - i.e. trying to capture HDV on DV project and vice versa. It was working fine, but I have reinstalled Windows and Adobe since then..
  5. try capturing with hdvsplit. easy and free. then import into cs6.
  6. I tried HDV split, the file (AFAIK came out 720x576) and for some reason wouldn't import into Premiere Pro
  7. Originally Posted by maxruddock12 View Post
    that would be strange. HDVsplit only captures HDV 1440x1080. 720x576 would be DVavi output, not even in the same ballpark. sounds like your cam is in the wrong mode or is no longer working properly.
  8. Maybe it was but resizing it then. I just assumed as when I opened the output file with VLC it only filled a quarter of the screen or so, nothing like it normally would for a native HD file. Might have another look tonight, still doesn't explain why Premiere Pro won't capture...
  9. use mediainfo on the captured file.
  10. And try changing your file extension to .mts .m2t or .mpg and see if that makes any difference. Also try .dv or .avi. mp3 still makes no sense.
    Jul 2012
    Russia
    Yeah, got the same problem with my HDR-HC1E.
    Was trying 2 capture even using Sony Vegas. Vegas understand it's own captured files, but Premiere has not. Not his own, and not veags .m2t files.
    Still searching for the answer.
    Adobe Encoder and Adobe After Effects can't understand this .mp3 and vegas-m2p files 2.
    MediaInfo says about video-side of that .mp3 files:
    - MPEG Video
    - HDV 1080i
    - Version 2
    - Main@High 1440
    Pretty simple.
  12. I am the same issue anyone can help
  13. Hi,
    I've the same problem with my Canon HV30. Amazing: in PR CS5 everything works perfect and in CS6 i cannot capture HDV. Tried everything but nothing works. In CS6 i only can capture DV.
    Herman.
  14. I have tried HDVSplit which captures the video, but it is a m2t file and when I tried to import it to premiere pro cs6 this giving me and error code. I don't understand why because Cs6 it can import m2t file can anyone help I have some footage to edit and it is driving me nuts
  15. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    hdvsplit is supposed to capture to .m2t that's the HDV file, same as on the tape. can't help with cs6, but all versions of premiere pro before cs6 have been able to use hdvsplit HDV .m2t files for at least 6 years.
  16. Originally Posted by hk291053 View Post
    Hi,
    Herman.
    Did you set the capture format to HDV ?
    Scroll down to the middle
    http://forums.adobe.com/message/4709304
  17. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    even when it worked premiere never "captured" HDV, it converted to i-frame .mpeg, not .m2t files.
  18. Member
    Apr 2003
    Have you updated to the latest version or checked what's been fixed in the latest patch?
    I tried capturing from my HV20 and initially PP locked up when i tried to edit capture settings. I had to turn off the camera, load PP, change the capture settings and then turn the camera on.
    Brainiac
  19. Banned
    Sep 2013
    Iran
    Problem solved: I could change the file format of the mp3 files to m2t files which were playable and editable on video editing software. My Premiere also had captured into mp3 files of giant sizes (which meant video was captured also). Now I don't have a problem playing them. Thank you, smrpix for the help. I had tried earlier converting to avi, mpg,... but none worked.
    Jan 2015
    Greece
    How did you it, Siamak?
  21. Banned
    Sep 2013
    Iran
    i only change the extension part of the file name via right clicking on the file and renaming it.
    Sent from my HTC Ruby using Tapatalk 2
  22. Member Cornucopia's Avatar
    Which means it was never really mp3 to begin with but that your .ts file was somehow being renamed. A simple MediaInfo readout would have clued everyone in on what to do.
  23. Member
    Jan 2015
    Greece
    Sorry but it does not work. Although I convert the files to .ts and .m2t, I can not run with wmp or import them in adobe premiere because not recognized by these programs. The files run only with gom player.
  24. Member Cornucopia's Avatar
    A simple MediaInfo readout would clue everyone in on what to do.
  25. Member
    Jan 2015
    Greece
    The solution is here :
    https://forums.creativecow.net/thread/3/953561
    Windows 7 (64-bit)
    Canon Vixia HV30
    Adobe Premiere Pro CS4 (5,6)
  26. Banned
    Sep 2013
    Iran
    Excellent! Thank u very much indeed
