Hi there,
I've read a number of threads but am slightly confused.
I've got a bunch of DVD's that I want to convert to store on my htpc. I currently stream (using Windows Media Center) from the htpc to the xbox 360 over Cat5 in another room.
I've read that the xbox 360 is pretty limited in what it can play - presumably that is the case with streaming as well?
I was planning on using Xvid4psp and using AVI format with Xvid (Q2.0 HQ) encoding and AC3 (640k) for audio. Is that the best option?
Ideally I wanted to keep the DVD menus - some of the DVD's are for the kids and have various episodes within them. So either would want to split episodes and have them as separate AVI files or have them as one combined with the DVD menu in tact.
Any thoughts - is this the best option?
Forget dvd menus.
But you can stream dvd isos with for example ps3 media server and maybe some plugin for windows media center(like http://www.howtogeek.com/howto/11071/automatically-mount-and-view-iso-files-in-windows...-media-center/ ) . Then can you skip the converting to some other video format, you just rip the entire dvd to one single iso. But I don't know how well it works for episodes though. -
I don't know how well PS3 Media Server works or doesn't work, but you could also rip to ISOs and buy a streaming media player like one of the Western Digital models. Those are pretty small in size.
Streaming From PC To Xbox 360 - tvmobili
By aaronoafc in forum Media Center PC / MediaCentersReplies: 0Last Post: 27th Jun 2012, 10:46 -
Xbox 360 and PS3 format for streaming
By robotball in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2011, 15:03 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
Ripping DVDs for Xbox 360 help
By mikemar in forum Media Center PC / MediaCentersReplies: 8Last Post: 20th Jul 2009, 19:59 -
Xbox 360 to offer Netflix HD streaming in November
By yoda313 in forum Latest Video NewsReplies: 9Last Post: 31st Oct 2008, 11:38
