Okay, I accidentally posted this in the wrong forum earlier. Please forgive me. I am trying to burn a windows media clip to a vcd. I followed the VCD all in one guide to the letter and everything seemed to work except my dvd player, Samsung DVD/VCD player says, "Cannot read disc". I first used DUB to save the audio to a separate file. I then use TMPENgc to convert the video and audio to a mpeg file. I then used VCDEasy to burn the cd. The process all flows very smoothly and I get no errors but then I can't play the freaking cd! VCDeasy creates four folders on the disc one of them being the mpegav folder that I know is important. Still, it doesn't work. Please help me!!!!
Model number on that Samsung?
Do other VCDs play in the same player? If so, are they factory-pressed CDs, or CD-R/RW recorded VCDs?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I'm not sure of the model number. However, I do know that it plays VCD disc because the manual says it does. It should be able to play all VCD, CD-R, CD-RW with recognizable formats.
lol, when the manual says it plays Video-CD it is refering to factory pressed VCD's NOT Video-CD's on CDR/CDRW.
The manual MUST state that it plays CDR/CDRW, does it?
Some DVD players DO NOT play VCD's on CDR/CDRW at all.
adding subtitles isn't working anymore
By kategabrielle in forum ffmpegX general discussionReplies: 3Last Post: 26th Jun 2010, 05:36 -
HDTV to DVD isn't 16:9
By sambat in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 16:54 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Isn't this annoying?
By Midzuki in forum FeedbackReplies: 17Last Post: 4th Feb 2008, 13:34 -
Vista DVD Maker (isn't working)
By naomi c in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 05:30
