I want to know how to find compression ratio for
<IPPPPPPPPPPPPP>I (H263)
Assuming that the average compression ratio is Cr=15 for I frames
P frames is 40
B frames is 80
I know that compression ratio is
Cr = original/compressed
but how does that help if we have an average?
The compression ratio is usually stated as the average for the entire video. Each I/P/B frame will have a different ratio. I don't know any program that will tell you the average of all I frames, all P frames, and all B frames, separately.
So
I frame 1/15 =0.066667
P frame 1/40 =0.025
B frame 1/80 =0.0125
Is that what you mean by? -
I don't know what you're asking. There is not a fixed ratio between frame types.
Need help with compression
By dfreeman1971 in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2010, 02:18 -
Movie resolution, aspect ratio, quality, size, and compression relationship
By mario595 in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2010, 19:52 -
Better Compression?
By anirban in forum Video ConversionReplies: 20Last Post: 5th Oct 2008, 18:19 -
Question about Compression ratio
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 12:30 -
Compression
By darts44 in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2007, 23:51
