More specifically, I'm looking for a camera that I can plug into a pc with just a usb cable and transfer the video file off the camera on to the pc without having to use a video capture device while keeping the original timestamp with the file. Any suggestions would be fantastic, thanks!
are you looking for a consumer cam or pro? price range? most cams only have the timestamp in the file name these days.
Thanks for taking the time, price isn't a big concern, but neither is professional-grade quality. I'm open to any range of cost or quality, it's all about what's cost effective for us I guess. Size of the camera is definitely a consideration, as it will need to be used in public places somewhat discreetly. Also, battery life and storage are considerations, but not nearly as important. Thanks again and any suggestions would be great.
PS I have heard that there is a slightly older model Panasonic that would work, I'm not sure the model number. Any older models would be fine as long as the quality is reasonable.Last edited by jnmoyer; 9th Jul 2012 at 15:08.
I have been using a Sony HD-videocamera for some years now but wanted a smaller camera to replace it. As the videocameras dont have optical finders any more I changed to a Sony hx9v compact camera a year ago. I am very satisfied with it, as it is very small and handy. The specifications are just as good as a for a normal HD-videocamera.
It registers metadata including timestamp.
This was a must for me and I asked Panasonic as they had a similar model and it did not register timestamp as I suspected. The reason I asked was that I had received some original clips from a Panasonic-camera and they did not show timestamp.
How can I add a running date/timestamp to a video? (hh:mm:ss format)
By quantice in forum Newbie / General discussionsReplies: 3Last Post: 19th Mar 2012, 12:34 -
How to put/print timecode/timestamp on a video
By truth of life in forum EditingReplies: 0Last Post: 11th Mar 2012, 10:29 -
Good Quality HD Video Camera ?
By PowerFalcon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Dec 2011, 20:38 -
Capturing HD Video with original Timestamp
By jnmoyer in forum Capturing and VCRReplies: 20Last Post: 31st Oct 2010, 21:54 -
A video camera with the quality of an eye
By Northern in forum Newbie / General discussionsReplies: 13Last Post: 17th Oct 2010, 13:40
