Hello everyone!
I'm trying to capture betacam sp (via s-video) but without success.
I am using:
_pc Windows 7 ultimate 64 bit service pack 1 | 4Gbs ram | Intel quad core CPU Q9400@2.66GHz 2.66 GHz | ATI Radeon HD 5800 Series | soundmax integrated digital HD audio
_placa capture Pinnacle systems MovieBox DV [Video input and output: s-video, composite | audio input to output: left, right | dv two-port]
_videocassette player PVW-2600 Betacam sp
What am I doing wrong? Really need to capture.
Waiting for feedback.
Best regards!!!
Results 1 to 9 of 9
Couple of things you don't mention in your post:
Does your pc have a good firewire port?
How do you know that your supplied "Studio 8" software supports Win7, or 64bit, or 64bitWin7?
or are you attempting to use a different capture software?
edit: also, have you correctly set any hardware/firmware switches on the box itself? -
IME you can't always transmit the full quality of Beta SP via S-video. Beta SP is a component format, and the S-video chroma sometimes isn't quite good enough. Depends somewhat on the capture device, and a lot on the content (which might have been through a composite workflow anyway!).
Cheers,
David. -
Thanks for the replies!
Yes, the moviebox can capture with other input, and also with s-vídeo when it's connected to a mini-dv camera.
I am using Adobe Premiere CS5 and trying to capture through it.
I believe it's a good firewire port - always used it, even when capturing, and never had problems with it. I've used the presets from the firmware switches on the box. -
Yeah, but WHICH presets? Some are appropriate for NTSC areas, some for PAL areas, etc...
Have you successfully used this combination (MovieboxDV->Firewire PC port(Win7-64bit)->Premiere CS5->DV file) before?
Improving Betacam video resolution
By carlmart in forum Video ConversionReplies: 39Last Post: 28th Feb 2011, 13:47 -
Capturing Betacam SP video
By jbigfoot in forum Capturing and VCRReplies: 2Last Post: 15th Mar 2010, 18:47 -
What is a Sony BVW-40 Betacam Recorder good for?
By Skubalon in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2008, 18:27 -
Digital Betacam Models and Specs
By seb.tatut in forum Newbie / General discussionsReplies: 8Last Post: 7th May 2008, 15:24 -
Betacam SP Sizes
By The Sumerian in forum MediaReplies: 2Last Post: 9th Sep 2007, 14:02
![Computer details: Intel(R) Core(TM)2Quad CPU Q9400 @ 2.66GHz 2.66 GHz
4 GB
64-bit operating system | windows 7 ultimate [service pack 1]
ATI radeon HD 5800 Series
AMD high definition audio device | soundMAX Integrated digital HD Audio Comp](/images/buttons/computer.gif)
