Hi!
When I run mkv-muxer in MEGUI, set all parameters and then click on "Queue" nothing happens at all! The window remains there, the queue stays empty, no error message. It worked fine before, must have something to do with an update. Any ideas how to solve this?
Bye,
dag0
I've no idea why it won't add the job to the queue. Is it just the muxer which won't work on it's own or are you having muxing issues when encoding?
In the MeGUI folder (on XP it's C:\Program Files\MeGUI\tools\mkvmerge) there's a file called mmg.exe Try running it instead. It should run MKVMergeGUI, which I prefer to use when just muxing something anyway. If you like it, maybe create a shortcut for it. -
Thanks for answering. The problem occurs only with the muxer not with the extractor. And yes: the MKVmergeGUI seems to work, thank you!
FLV/mkv muxer
By ayim in forum Video ConversionReplies: 3Last Post: 24th Nov 2012, 10:20 -
How to work with Muxer Settings?
By ellygirl95 in forum SubtitleReplies: 9Last Post: 27th Jun 2010, 09:39 -
Extract subs from MKV (MKVextract doesnt work) and Re encode to xbox 360
By Snipergod87 in forum Newbie / General discussionsReplies: 6Last Post: 6th Oct 2009, 18:51 -
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 7th Mar 2009, 00:46 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05
