I’m looking for some opinions. I’m going to archive some Mini DV & VHS tapes.
My intent is to archive these tapes to a hard drive and then DVD’s and maybe edit them down at some point. I may also want to view them on a Divx friendly standalone DVD Player. I’ve tried capturing with DV, Huffyuv, Divx and Xvid codecs.
What I’m looking for is the best quality without a huge file size. Can anyone who’s done this type of thing recommend a codec and settings?
Thanks…John
Results 1 to 10 of 10
The signal coming out of the vcr being top field first you want to avoid DV (it record bottom field first)
If you want quality you can safely discard xvid, Huffyuv record huge files that leaves you with Lagarith.
Personnally i use huffyuv (i bought a 500gb hdd dedicated to capture) but i have tested with lagarith, it works too.*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
The signal coming out of the VCR is neither top field first nor bottom field first. It is a series of fields alternating between top and bottom fields. It can be captured TFF or BFF. It can be burned to DVD as TFF or BFF. Film based material should be inverse telecined back to 23.976 progressive frames before making a DVD (or Xvid AVI, or h.264 MKV, or whatever).
All the lossless codecs don't compress much -- especially noisy VHS caps. All the high compression codecs are too slow for real-time capture, or give poor results with settings that are fast enough. Capture with a lossless codec like HuffYUV then convert to a lossy codec with slow, high quality settings. And clean it up with some filtering before encoding.
DV is a fair compromise. It only has about 180 lines of horizontal resolution for the chroma channels but NTSC VHS only has about 40 lines of chroma resolution, so you don't really lose anything. If you're really concerned about whether the video is TFF or BFF convering to DV BFF to TFF is as simple as shifting the image up or down by one scan line.Last edited by jagabo; 4th Jul 2012 at 12:20.
To go through all that capturing work and then waste it with crap like Xvid/Divx is just that....a complete WASTE. Xvid/Divx is a step DOWN in quality from DVD/MPEG2. You mentioned the word "archive"....that to me means at LEAST DVD/MPEG2 at a high bitrate.
Xvid/Divx can be just as good as MPEG 2 with a smaller file size. Or better quality at the same size.
Thanks for your cimments, guys. I think I'm going to go with MPEG2. Can anyone recommend a capture program that lets you adjust the codec & bitrate?
John -
Depending on the hardware involved....I use Magix Movie edit mostly.
Real time softare MPEG 2 compression uses a lot of shortcuts to get the speed up. So it doesn't give as good image quality as a capture to lossless and subsequent slow conversion to MPEG 2.
Freeware App To Change Video File Size, But Not Video Or Audio Codecs
By LouieChuckyMerry in forum Video ConversionReplies: 4Last Post: 19th Jun 2010, 09:06 -
So many Video Codecs to comprehend; best Video compression?
By bulava in forum Video ConversionReplies: 7Last Post: 3rd Mar 2009, 15:01 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Video Codecs
By aka_little_dragon in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 12:19
