DivxMediaBuilder
File > "New with wizard"
Added AVi file, clicked Next.
Click Create Title Menu, clicked Next.
Loading Menus, ok.
Clicked Create
Messages: Creating menu for titles...
Creating menu movie... 1
"An error occurred whilst creating the AVI: 0"
Then, "Error getting info for file"
Then, "Error getting info for file C:\Program Files\DMB\" showing Setting menu properties
I'm not referencing something.
Anyone with ideas?
the software is not likely to work. it's been abandoned for 5 years.
OK, then.
What is the favored software for inexpensively building and burning a DVD that has a menu, background, selections for avi files? -
If you're just looking for an all-in-one-type software that'll take whatever videos you input and create a DVD-Video disc, without much effort, there's programs like AVS2DVD (freeware). The author posts regularly to VideoHelp, and there's a dedicated support topic here on the forum. (Note that if you do try AVS2DVD, be sure to check the settings before you use it - it defaults to creating PAL-format DVDs, for example.)
Other choices include FAVC, DVD Flick (both freeware, though they haven't been updated in some time), and the commercial ConvertX2DVD.If cameras add ten pounds, why would people want to eat them?
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
DivxMediaBuilder "No suitable decompressor..."
By SWMagic in forum Authoring (DVD)Replies: 6Last Post: 3rd Jul 2012, 10:49 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"attention chrissy boy" Update message shown whilst burning.
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Jul 2010, 11:36 -
"An unhandled exception occurred in 3rd party module and will be close
By BLSAMPLES in forum ComputerReplies: 4Last Post: 12th Jul 2009, 22:30
