Results 1 to 15 of 15
  1. Is there any software that can help get rid of the grany look that vhs tapes give off, Im working with Sony Vegas 11 Pro but was wondering if there are any other tools that can help me out
    Mar 2008
    Post a small sample (up to 30MB) of the source you're working with.
  3. Here is the file, as you can see it is pretty grainy. This is before I used the Soft Contrast effect in Sony Vegas
  4. neat video has a plugin for vegas (and other programs like vdub), is gpu accelerated and fairly intuitive to use
    http://www.neatvideo.com/
    vdub has dozens of filters you can try
    avisynth has dozens of filters and is free (but there is a bit of a learning curve)
    Mar 2008
    I didn't mean a still image, I'm talking about a clip of the video itself.
  6. here's part of the video, as you can see its grainy
  7. Originally Posted by poisondeathray View Post
    I've heard of NeatVideo, how can I get a full lenght copy for free it works pretty good
  8. How did you capture the VHS tapes?
    You could probably have done a better job capturing it
    <2Mb/s @ 640x480 isn't really a good bitrate for MPEG1. You should have used something much higher
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    That's not grain, that's snow. And you didn't deinterlace, so half the picture field is missing. And the noise is compression blocks formed from using a very low bitrate.
    That one's a goner.
    May 2007
    Australia
    1. Learn to program
    2. Figure out the algorithm they use.
    3. Create your own version.
    Other than that pay people for their hard work.
  11. You should capture at 720x480. If your capture device only supports MPEG capture use as high a bitrate as you can. Over 8000 kbps is best. Make sure your caps don't have dropped and duplicated frames (like are seen in the sample you posted). Then you'll have something decent to work with.
  12. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Find a rich wife. I got all my stuff free that way.
  13. Banned
    New York, US
    Just follow the above link. Or here, again: http://www.neatvideo.com/
    This is pro quality stuff. The trial is free (works with max image size 640x480). Retail versions work bigger DVD sizes. Get the Home Edition, the Pro version is the same but for really big formats. Considering what it can do, and considering that pro shops use it, I think the product is under-priced. Extra copies get a discount, so I have 3 copies.
    NeatVideo is a spatio-temporal filter. Don't use the defaults; they're too aggressive, for really really really horrible stuff. Learn to tweak the settings. It won't take long, once you get your hands on it. There are many posts here with tips for NeatVideo. Somebody should make a sticky or tutorial for it. Don't look at me, I'm too busy using it right now. But it's an idea.
    User guide (now, stop and think about it: How many denoisers give you a pdf user guide to tell you what the hell's going on?). NeatVideo User Guide for Vegas. They also have a forum.
  14. Neat Video isn't going to fix the problems you have of recording with too little bitrate, dropped frames, and duplicate frames. Get a decent capture first. Then worry about noise and other fixes.
  15. Banned
    New York, US
    True. Avisynth, VirtualDub, Vegas, etc., can do a lot but you have to give 'em something to work with.
