  1. Hello.
    I authoured a DVD using AVS Video Converter and, then, use DVD shrink to reduce the size but when I try to burn it, it doesn't work. I tried this on two different discs (both times using a different one - first, I used Ashampoo 6 and, then, I used the Free Studio burner) and in the case of the Ashampoo, after the burning finished, the verification failed and in the Free Studio one, it gave me a disc error.
    What should I do? Is my using DVD Shrink causing a problem?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by Anonymous1a View Post
    What should I do?
    Use ImgBurn
    No.
  3. Originally Posted by hech54 View Post
    No.
    That's true, but it's still a dumb idea to reencode it followed by using Shrink on it. You reencode it to the correct size to begin with.
  4. Originally Posted by manono View Post
    No.
    Umm, although I understand most of the basics on this stuff, I am not an expert and, so, I didn't really get what you mean. Can you please explain, in more simpler terms? IF you mean to tell me that I should have taken care so that the final output after using DVD Shrink should be the correct size to fit within a DVD, I did take care of that and the size is not the problem. IF you mean something else, please clarify.
    Also, you guys are telling me to use ImgBurn but I have VOB files, not an ISO image. So, I should convert it to an image first now? Which software should I use for that?
    Thanks a lot for the help and I am sorry for the trouble my ignorance is causing you all.
  5. Originally Posted by Anonymous1a View Post
    I mean you shouldn't have had to use DVD Shrink to begin with. You should have encoded it for the proper size in your conversion program originally.
    No, ImgBurn can easily burn the TS_VIDEO folder. You don't need to convert it to an ISO first.
  6. Originally Posted by manono View Post
    Oh, thanks! The reason I used DVD Shrink was that I was trying to put five clips of about 45 minutes in one DVD and for me to do that in the original conversion program, I would have to reduce the bitrate and, thus, the quality. From what I have seen on Youtube, they say that DVD Shrink doesn't lose as much quality and reduce the sizes a lot more (I have also done random clips on it and I think I would agree).
    As for the ImgBurn, I don't really know how to do that. Which option should I use on Imgburn for that? The "Write Files/Folders to Disc"? Will this also allow me to play it on a DVD?
    Sorry for the added trouble again!
  7. Originally Posted by Anonymous1a View Post
    Well, I never have (and never will) used this AVS Video Converter you're using. In general, though, an encoder will produce better results than will a transcoder such as DVD Shrink. I don't know if your program transcodes or encodes. Maybe it transcodes in which case you're right - DVD Shrink will do a better job if you use it from the beginning. Transcoding followed by transcoding yet again still isn't such a good idea.
    "Write files/folders" to disc' followed by "Browse for a folder", and select either the VIDEO_TS folder, or the main folder, called Movie Name, or something like that, inside of which are both the AUDIO_TS and the VIDEO_TS.
