Howdy All
I am interested in capturing the VGA output from another computer, usually 1024x768, but maybe some day upto FULLHD 1920x1080. I am more interested in an internal card, but could use an external usb for the time being. I am most interested in a SDK that I could use to control that card from a programming lang like Delphi or Visual Basic. For winxp and win7.
Any Suggestions?
Thanks so much
I can only remember seeing a couple of internal capture device that capture VGA
https://www.startech.com/AV/Converters/Video/PCI-Express-HD-Video-Capture-Card-1080p-HDMI-DVI-VGA-Component~PEXHDCAP
http://www.avermedia-usa.com/avertv/product/ProductDetail.aspx?Id=500
The AVerMedia device looks like the closest to what you want.
Epiphan makes a number of external VGA capture devices, but you will have to read the specs carefully. As resolution goes up, the available capture framerate goes down. This one is their most advanced model http://www.vgacapture.com/vga2usb-pro-frame-grabber/ -
I was hoping to get some users' input as to their preferences, especially with regard to a software development kit (SDK) that would allow an application to control the capture and output, etc.
Thanks -
I can only tell you that that there is an SDK available for the AVerMedia DarkCrystal HD Capture VGA Plus. I can't tell you what the SDK is like, since I haven't used it.
Here is a link for the data sheet, which contains information about the SDK: http://www.avermedia-usa.com/AVerTV/Upload/ProductImages/C199X+DarkCrystal+HD+Capture+...+Datasheet.pdf
Video Capture Device - Suggestions
By rancineb in forum Capturing and VCRReplies: 12Last Post: 20th Aug 2011, 19:27 -
TV/VHS tape Capture card suggestions for my pc?
By drwho in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2008, 19:49 -
Capture Card Suggestions?
By duderdude2 in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 00:42 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 02:48 -
Dual Video Card Suggestions
By wwaag in forum ComputerReplies: 2Last Post: 29th Apr 2008, 14:09
