My EVGA 7300GT video card has burst its little electrolytic capacitors and is sleeping with the fishes. Can anyone recommend a replacement ? I use the output for VHS video correction and need VGA and DVI / HDMI outputs only. My PC power supply is rated at 300 watts and I'm still running Windows Vista.
Any help would be appreciated !!
Just about any modern low power card with the right connectors will be fine. For example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102933
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130656Last edited by jagabo; 2nd Jul 2012 at 09:59.
Force FFDSHOW?
By therock003 in forum Software PlayingReplies: 6Last Post: 25th Feb 2012, 13:24 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
Force 16:9
By Giorgis in forum Authoring (DVD)Replies: 10Last Post: 4th Oct 2010, 01:50 -
Force autoplay
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Jul 2009, 18:48 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57
