Hey guys, I've been using MeGUI, and switched to TX 264 for some reasons.
However on MeGUI I could set the Priority of the encode to High, which would allow me to encode a 22 mins episode within 7 minutes
On TX 264 a sample (5 minutes) would take me about 12 minutes. Any way on how to set the priority to high?
CPU usage is a plain 29%, and it's taken all by the x264, I just wish it'd take away all my CPU usage like MeGUI so that it'd speed up.
Using an i7 with 6GB RAM, ask about any additional info if needed.
Setting the priority high will not make it encode any faster unless you have some other CPU hungry program running at the same time. The best solution to that is to shut down that other process. Priority is just that -- which program gets more or less CPU time when multiple programs are asking for it. If only one program is running it gets as much CPU time as it asks for.
If Task Manager shows the System Idle Process is receiving the bulk of CPU time you just have a bottleneck in the program. Ie, maybe it needs to be set to more threads. Or a particular filter is running in a single thread, starving the encoder.
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 17:22 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.
By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
