Results 31 to 32 of 32
Eh Webwalker, I just re-read your OP and 2 questions came to mind, where did you get those TY discs and how old is your burner?
You gotta be careful where you get your discs from, I remember a few years ago there was a bunch of fake Taiyo Yuden discs on the market. They had the right MID and when you opened the cake box, you'd get a whiff of that peachy smell TY's are famous for. I got a batch of those from Futureshop; they would burn ok on my Plextor 712, but they weren't anything like the true TY's I'd used before (I use to scan most of my discs with PxScan, back then).
An old burner won't burn as well as it used to, it's a case of the pits not being fully formed. How old is too old depends on how much usage it's seen (did you burn a bunch of discs at once, has it gone through 1000's of burns...), the environment it's in (temperature, dust, humidity...) and even the kinds of discs you use (RW's need more laser power). That Benq 1640 dates back around 2005; I don't know how long you've owned it, but I can tell you I just replaced a Pioneer I installed in 2007. It was burning DVD5 discs fine, but wouldn't burn DL discs. I took it apart and tried cleaning it, but that didn't help. So, I just replaced it, with drives costing $25, it's hard to justify risking your data.
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Digital optical vs. digital coaxial cord
By coody in forum AudioReplies: 3Last Post: 12th Dec 2009, 08:57 -
Layer rot on DVDs?
By lilblu in forum MediaReplies: 8Last Post: 20th Feb 2008, 14:22 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
If I buy a 14 inch SDTV with a digital tuner, can i watch digital programs
By davidsama in forum DVB / IPTVReplies: 3Last Post: 6th Sep 2007, 10:25
