I've run AnyDVD to backup my Dirty Harry 3 blu-ray to hard disk. Afterwards the conversion of the main movie worked fine. But no success with the extras -which are VC-1 encoded- with any program I tried directly, e.g. Handbrake, meGui, SolveigMM Video Splitter (after remuxing). I re-tried copying the BR to hard disk using DVDFab Passkey and DVDFab HD Decrypter, too. Conversion failed, either. So I took on another way, a long long way.
Here's what I used:
- Blu-ray playing software, e.g. TMT 5
- Fraps
- VirtualDub
- VfW codec of your choice
- ffdshow
Step 1:
- start Fraps and set up destination path, fps (in my case 60 because source was 29.97 fps NTSC) and hotkey (in my case F9)
Step 2:
- play blu-ray and start your chosen title
Step 3:
- as soon as your title plays hit (F9) and wait
- when your title has finished playing hit (F9) again so recording stops
Step 4:
- load the resulting .avi in VirtualDub or your favorite video editor and convert it
Again, I used this to convert VC-1 encoded titles to x264 because each and every other tool had failed me. Altogether, software showed some strange behavior with this. MPC-HC played the title itself flawlessly. Opening it with VDub worked fine - for video, audio was not available. AviDemux, XMedia Recode, SolveiggMM Video Splitter (after remuxing) failed. Green video display and distorted sound.
Don't know why those tools had acted that way. The title must have been decrypted thoroughly because MPC-HC played it with no problems.
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
For those who don't understand, leghorn used a screen capture program to record his video in real time to AVI format which he then re-encoded.
You know, when your neighbor asks you to walk across the street to go to his house, one option is to walk all the way around the earth in the opposite direction to get there. But I don't recommend that either.
Good grief, man. BD-rebuilder is fully capable of encoding progressive VC-1 video without any problems. It would have been a lot simpler to do that. It may or may not have problems with interlaced VC-1. DVD Beaver says the region A Blu Ray release is 23.97 fps progressive VC-1. It is highly unlikely that yours is different.
http://www.dvdbeaver.com/film2/DVDReviews37/dirty_harry_ultimate_collectors_blu-ray.htmLast edited by jman98; 30th Jun 2012 at 22:49. Reason: fixed typo
Of course there are those times where there is a gigantic crater of lava and toxic waste between you and your neighbors' house. Then, it's appropriate to go the long way around. (e.g.: screencapping some proprietary/DRM securitycam shit)
Scott -
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 09:36 -
Subtitles stay too long when converting MKV to AVCHD for PS3 with tsMuxer
By WFlits in forum Video ConversionReplies: 5Last Post: 31st Oct 2010, 06:15 -
Long shot: video base in french
By B-Twien Bytes in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2010, 06:50 -
Converting a few long avi into DVD using ConvertxtoDVD
By jackwolf in forum Video ConversionReplies: 2Last Post: 29th Jul 2009, 23:05 -
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 23:39
