I have Monsters Inc. which is a realy good quality divx dvd rip. I want to make a (s)vcd out of this movie so that i can watch it on my dvd player. How can i convert it and not lose any quality. I tried encoding to standard vcd and the quality was horrible. I tried encoding it to svcd 2-pass VBR but it wouldnt encode. The screen area where it shows the video as its encoding was just black and it indicated ont the progress bar that no frames had been encoded. I opened up the encoded file and it was just black. I want to keep the quality the way it is because it is really good. I have the apex ad-500w so i can play xvcd and everything. Any help would be greatly appreciated.
btw, i have TMPGEnc 2.53 Plus. And i have divx 3.11 codec and divx 5.0 codec.
OK...now i get it. Thanx. Any reccomendations on the second question? On how to keep my quality.
The quality depends on the bitrate you encode at and what encoder you use.
Best case is using CCE at 3 or 4 pass VBR, and spreading the movie over at least 2 CD's - since its a cartoon, I'm assuming its about 90 minutes long so 2 CD's should be fine.
With TMPGEnc, quality wise, you're better off using an older version - anything pre v2.0 should be better, but I'd be guessing at which is best. You're going to get blocks in dark areas in TMPG, there's no way around that that I have found. And as above, spread it over 2 or 3 CD's - get a bitrate calculator from the 'Tools' section to eliminate the guesswork.
JJ -
Is CCE the best for getting good quality encodes? Should i encode this to VCD or SVCD?
Originally Posted by JJamez
I have tried high bit rate and variable bit rate settings and 100% quality and none of it fixes the problem.
It's not really "macro blocks" but rather what seems to be an over-amplification of very faint "noise" in the dark areas of the source mpg/avi stream.
Should I use CCE with a Flaskmpeg front end instead? How is CCE at mpeg1 encoding (I only see references to its wonderful mpeg2 abilities)?
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
Problem doing two pass encoding
By ss30 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 6th Dec 2007, 13:37 -
HCenc encoding problem (2nd pass)?
By ecc in forum Video ConversionReplies: 49Last Post: 29th Nov 2007, 01:22 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 09:44 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
