Hi,
I've been searching the net for a way to adjust the space between lines of subtitles in aegisub but i couldnt find anything. Seems like its not possible which i find very odd considering how advanced and cool this program is. Is there any way to do this without having to split the lines in 2 subtitles and manually position them?
Thank you.
The ASS subtitle format unfortunately doesn't support modifying the line spacing. There's a few kludgey ways to increase it, such as "{\fscy400\fscx0}\h{\fscy\fscx}first line\Nsecond line" or just modifying the font used, but no way to reduce it short of positioning each line separately.
Thats a nice trick, but seems it only works for increasing the space and i want actually to decrease it. So there is no similar trick to do that?
Thank you.
Aegisub effect
By xxxThiefxxx in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 15:35 -
VirtualDub/Aegisub Problem
By FrankXXX in forum SubtitleReplies: 0Last Post: 1st Oct 2010, 12:56 -
aegisub
By simonrule in forum SubtitleReplies: 2Last Post: 9th Nov 2009, 05:05 -
Aegisub newbie
By diablo_jones999 in forum SubtitleReplies: 0Last Post: 12th May 2008, 12:10 -
audio out of sync using aegisub
By denadel in forum SubtitleReplies: 3Last Post: 21st Sep 2007, 17:00
