It has been awhile since I last posted.
I was trying to do some video capturing using VirtualDub, and encountered the following error when setting up the audio for MPEG3:
ERROR 422:ERROR:Cannont add wave buffers
Does anyone know what is causing this error, it is causing the computer to totally lock up?
The only other audio settings I have to select from are PCM and some other ones which will not allow playback with the avi's that I'm making.
What are some recommended CODEC's for audio that you good people are using for capturing?
My video capture card is a 32Meg ATI Rage Fury Pro installed in a 733PIII with 256Megs of RAM.
I have captured video a long while back and things went fine, but for some reason this error occurs now.
Thanks in advance for your help.
Results 1 to 1 of 1
VirtualDub Analogue Video Capturing Problems
By Dr Gonzo in forum Capturing and VCRReplies: 17Last Post: 22nd Sep 2011, 10:27 -
Audio Synch Problems AVISynth to Virtualdub
By magillagorilla in forum AudioReplies: 15Last Post: 19th Sep 2011, 23:05 -
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 14:49 -
Audio desync problems when capturing with Fraps
By ecjezl in forum Capturing and VCRReplies: 4Last Post: 29th Jun 2011, 22:48 -
What level should I set the audio to when capturing analog in VirtualDub
By drinklime in forum AudioReplies: 3Last Post: 20th Jan 2008, 08:45
