  1. I am new at using XMedia Recode. I am converting Uncompressed AVI (Lagarith) to Uncompressed MOV to edit video on a MAC. I see I can convert to ProRes using XMedia Recode, which is fine, but.... I was thinking of using PNG instead because it is lossless unlike ProRes which is lossy. I didn't see that in the list of Codecs of choice. Animation was the only one. Animation tends to be huge in comparison to PNG. Is there a way to add in PNG in the list by editing the "mov.ini" file in the format directory?
    Any experts out there with insight would be greatly appreciated!
    canada
    Thread moved to the mac forum where you can get more help.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    ...except XMedia Recode is a Windows program.
  4. Which is why I didn't post it here... sigh.....
    canada
    Thread moved to video conversion,please edit your original post since its not a mac you are using.
    Oct 2005
    666th portal
    iirc xmediarecode is based on ffmpeg which just recently implemented the mov encoding and i don't believe png was included at all. since you are already in the yuv color space prores422hq is probably your best bet if the mac can't handle lagarith or huffyuv.
  7. Yeah. I think I will stick to ProRes when I need to convert an AVI to MOV for editing on a MAC.
    Thank you all for you help.
