Results 1 to 10 of 10
  1. Hi guys
    I deleted some .mts files from my sd card before realizing the transfer to my pc was corrupt but files were ok and can't recover them. I've tried Stellar Phoenix Recovery but give me the files with 20 Mgb and each of them was 200 MgB. Any other program I tried isn't able to recover the files.
    They were very valuable videos because it was a shooting of a videoclip
    Does anyone know how to recover the files? I would appreciate any idea or tips.
    Please, please, please
    Oct 2005
    666th portal
    there are websites that claim to do advanced recovery for $$$. call one and get an estimate, as you tried one of the better software solutions and it didn't help. like http://www.krollontrack.com/
  3. I'm a Super Moderator johns0's Avatar
    canada
    Try recuva,it should work as long as you didn't put record anything else with that card.
  4. Tried recuva already and didn't find anything. I've recovered half of the .mts with PhotoRec (best software I've ever seen and works in great ms-dos) but the other half is still missing...
  5. Banned
    New York, US
    The only software that actually worked for me (I tried 10 different products) was CardRecovery. It looks only for photos and videos -- you won't expect it to find .doc or other formats. The trial version lets you run it to see if actually works before you have to pay for it. I tried another 5 free packages, none of them found a damn thing. Two of them couldn't even recognize the SD card. Recognizes these file types:
    Common Picture Formats: JPG JPEG TIF
    Common Video Formats: AVI MPG MOV MPEG ASF MP4 3GP MTS
    Common Audio Formats: MP3 WAV
    RAW Image Formats: Nikon NEF, Canon CRW and CR2, Kodak DCR, Konica Minolta MRW, Fuji RAF, Sigma X3F, Sony SRF, Samsung DNG, Pentax PEF, Olympus ORF, Leica DNG, Panasonic RAW and more
  6. For the "other half still missing", I suggest that you create a disk image of your SD card, and then scan it with a video recovery tool.
    But first of all, have you checked whether your SD card is counterfeit?
    http://aeroquartet.com/movierepair/counterfeit
    Many SD cards bought from untrusted sources only have a fraction of the announced capacity, and cause permanent loss of footage.
    If your card is not counterfeit, let's do a disk image:
    - the disk image will be roughly the same size as your card capacity. it will contain all the data present on the card, including deleted videos (unless they have been overwritten by new ones).
    - instructions to create a disk image: http://aeroquartet.com/movierepair/dd%20for%20windows
    Then you can try video recovery tools on the disk image.
    In you are on Mac, you can use Treasured's DeepMediaScan, that provides an integrated flow: scan - clips mapping - recovery
    http://aeroquartet.com/movierepair/deepmediascan
    Good luck.
    -- Benoît
  7. After transferring photos from my SD card I put the card back in the camera and deleted them, as I always do. Unfortunately this time I forgot to transfer the video files also. Really don't like the Sony file system. Pain in the butt getting to the mts files. Anyway, I read this post and some other reviews on SD card recovery software. Seemed like CardRecovery would be the way to go. Specialized in photo and video recovery and quite a bit cheaper than some of the alternatives I was looking at. Unfortunately, I wish I had been a bit smarter about this.
    I have always used Pandora for recovery operations in the past. This time I opened Pandora and selected the deep scan option. It searches for specific file types and is recommended for SD cards. So I do that, but before I can start it doesn't have ".mts" as a searchable file options. Hmm.
    So I end up buying CardRecovery. Wish I had been more vigilant in using Pandora. CardRecovery found about 325 mts files on my card. The problem was it produced file clips that were no more than 25 seconds each. It appeared that it split the files up in to small parts. They played fairly well, but not great. and, of course, there's the major inconvenience of having a bunch of short clips with some defects in the video.
    On a whim my brain kicks back in and I decided to try Pandora again and not use the deep scan feature. Just the normal quick scan. Low and behold it recovered all my video without splitting the files. No breaks, defects or dropped frames. For a paid program that specializes in recovering camera images, I am really disappointed in CardRecovery.
    I'm out $39.95 for being stupid.
  8. Banned
    New York, US
    If the original videos were overwritten with new data, or if the sd card was reformatted, it's doubtful that anyhing would be recovered.
  9. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    One s/w solution that has worked well for me in the past for retrieving deleted .mts files from my SD cards is PCI Filerecovery. It's an old free program that is slow, but works perfectly for the task at hand........
    http://download.cnet.com/PC-Inspector-File-Recovery/3000-2248_4-10118663.html
    It saved my butt on more than a few occasions. Good luck!
    Dec 2014
    I had an SD 32GB card with corrupted files, not sure what happened to it, but I'm a wedding videographer and I needed those files! I paid for R-Studio, which found them, but could only recover 333K out of 1.2GB showing! Also tried DiskDrill Pro, Photo-Recovery, all programs I had to pay for, with no luck, then I ran across posting with PhotoRec from cgsecurity.org ( a free shareware program, not to be confused with Photo-Recovery from Wondershare.) It worked! found all my .mts files, although it doesn't specify it will even look for them: it renamed them all as .m2ts files, but I could see them all with VLC, so who cares? I'm definitely contributing $20 to this guy; out of all the programs I wasted money on, his was the only one that worked!
