As with this post: https://forum.videohelp.com/threads/347189-Adobe-Premiere-Pro-CS-5-5-YouTube-Export-Pro...66#post2170766
My goal is to duplicate YouTube's conversion process, but this time for my camera's lowest setting.
This time the approach I am taking is to load the file I am trying to duplicate into Adobe PP CS5.5 and then trying to match output settings to the source file. (In my opinion there should totally be a button for this so I can turn any video into a preset, but that's a feature request for another time. )
Will this even work?
The settings I am trying to duplicate are according to media info:
General
Complete name                            : E:\My Original Media\YouTube Experiments\LP%20Vixia%20HF200%20Reference.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 5.57 MiB
Duration                                 : 1mn 0s
Overall bit rate mode                    : Variable
Overall bit rate                         : 771 Kbps
Encoded date                             : UTC 2012-06-27 13:26:00
Tagged date                              : UTC 2012-06-27 13:26:00
gsst                                     : 0
gstd                                     : 60696
gssd                                     : B4A7DD402MM1340890103565282
gshh                                     : o-o.preferred.cbf01t04.v2.cache1.c.youtube.com
Video
Format profile                           : Baseline@L3.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Format settings, GOP                     : M=1, N=60
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1mn 0s
Bit rate                                 : 672 Kbps
Maximum bit rate                         : 1 380 Kbps
Width                                    : 640 pixels
Height                                   : 360 pixels
Frame rate mode                          : Constant
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.097
Stream size                              : 4.85 MiB (87%)
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 1mn 0s
Bit rate mode                            : Variable
Bit rate                                 : 96.0 Kbps
Maximum bit rate                         : 104 Kbps
Channel positions                        : Front: L R
Sampling rate                            : 44.1 KHz
Stream size                              : 710 KiB (12%)
Title                                    : IsoMedia File Produced by Google, 5-11-2011
As you can see the source file is 5.57MB
The closest I can get Adobe to approximate this is 8mb: and say it's for an apple ipad. The built in YouTube presets and the mpeg4 presets and formats are laughably wrong. They want to produce a file that's 54 megs, or some bizarre extension called *.3gp
Is there some better way to accomplish this goal? Some way of getting premiere pro to automatically match settings? If not, what am I missing?
It seems to me like I'm comparing apples and oranges, I can't seem for find hardly any of the stat from mediainfo as settings in the export dialog. It's like different naming conventions are in play.
As always thanks for your time and attention
