Years ago, I have transferred to DVDs some 60 hours of home video. It's a collection of videos of my son (since he was a baby) and my late wife. Using a JVC VHS/DVD recorder, I set the recording to two hours for all of them mainly to accommodate the 2 hour VHS tape. I also have Sony 8mm and Digital 8 tapes which contain one hour videos (I used firewire to record these 8mms).
I want to re-record those tapes again on DVDs. Would there be a noticeable difference if I set the recording to one (1) hour instead of two, assuming the monitor is 40" LED/LCD HDTV? Thanks.
Yes -- double the bitrate, about 150% of the quality.
It's going to look far cleaner, and have virtually no noise compared to the SP mode.
Read this: Is SP MODE the Best DVD Recorder Mode? (NO!)Want my help? Ask here! (not via PM!)
I agree. On a screen that big, you'll certainly notice a difference with home videos, especially on camera pans or parts where the camera isn't on a tripod.
You could also consider using dual-layer discs if you'd like to fit closer to two hours per disc -- although I'd recommend you have a set burned onto single-layer discs as well for backup. -
Thanks. guys. Now I have to buy tons of media. I might decide on single layer though.
Many DVD recorders don't support dual-layer media. Check the manual for the JVC recorder before you buy any. Verbatim makes the only good dual-layer media (DVD+R DL), and it has to be ordered online. It isn't cheap. Last time I ordered a 20-disc spindle from Amazon the price was $23.41, and there are others selling the same size spindle for more.
Yes, the Verbatim DL discs average a little over a dollar per disc these days for a 50 pack from most places.
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 13:35 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 06:23 -
why convert a MKV to DVD format took more than an hour ?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 19:34 -
Can't get my AVIs to make a 3 hour long dvd. :(
By Nicole78 in forum Video ConversionReplies: 5Last Post: 14th Apr 2008, 15:05 -
burning 1 hour of raw footage onto DVD
By sfischer in forum Authoring (DVD)Replies: 2Last Post: 8th Feb 2008, 20:28
