Someone sent me 3 videos. All 3 go squished vertically after about 5 seconds of play in VLC - but can be viewed
normally all the way through in AviDemux. I tried to SAVE AS MPEG-PS (.mpg) via COPY but the resulting mpg file
was the same....goes squished after a few seconds. Can anyone tell what is wrong with these vids....besides someone
using Nero to work with video?
Complete name : D:\Downloads\xxxxxx - xxxxxxxx.VOB
Format : MPEG-PS
File size : 275 MiB
Duration : 5mn 16s
Overall bit rate : 7 295 Kbps
Writing library : Created with Nero
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 5mn 16s
Bit rate mode : Variable
Bit rate : 6 958 Kbps
Nominal bit rate : 9 641 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.671
Stream size : 262 MiB (95%)
Writing library : Ahead Nero
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 5mn 16s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -160ms
Stream size : 7.23 MiB (3%)
Did you try DVD Patcher? (available in tools.) Adjust aspect ratio, patch "entire file." You may want to duplicate the originals for safety.
Looks like a nice tool but I have no idea what is wrong with these vids in the first place.
This came from one of those people that thinks VOB Files are "better" than the original MPEG2 file so all I have are the VOB files. I guess I'll back one up and run it through DVDPatcher for shits and giggles.
DVDPatcher didn't fix it. Re-encoding it with MainConcept fixed it. I may as well do a bit of filtering in VDub, replace the audio on them(they are music videos) and re-encode them. They are only VHS sourced anyway......never released to DVD.
Thanks Anyway!!!!
Macroblocks only at the first seconds of the video
By fernandovg in forum Video ConversionReplies: 9Last Post: 22nd Jun 2012, 10:29 -
First few seconds of media files stutter in VLC
By A Traveller in forum Software PlayingReplies: 2Last Post: 15th Sep 2011, 15:18 -
Removing the first 18 seconds of a video
By Simmons in forum Video ConversionReplies: 9Last Post: 14th Jun 2011, 06:18 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59
