  1. Member Ennio's Avatar
    May 2005
    Netherlands
    Hi everybody,
    For a future project I tried re-encoding a ntsc dvd-stream with x264 in MultiAVCHD.
    Input was 720 x 480 aspect ratio 4:3 (from dvd-image mounted)
    In the title-properties window of MultiAVCHD it says 720 x 480i (1.78) This is 16:9 AR?
    In the transcodewindow I left "Resize" to default: 720 x 480 (no change)
    No uncropping.
    After transcoding my output is 16:9.
    I checked the original dvd VOB's with mediaInfo and it definitely says 4:3. Somehow MultiAVCHD thinks the dvd is 16:9 anamorphic, my guess. The "alter detected properties" has no possibility to change AR.
    Does somebody have an idea?
    Ennio
    Edit: sorted it out, I had to resize to 720 x 480 (4:3) Didn't see it. Strange though why it says 1.78 it the 1st place...
  2. Having the same issue. Can anyone help with this?
