Col mio recorder nilox media pro m3 ho registrato una trasmissione da ingresso composito,otenedo un file mpg di circa un gb.
Sul mio pc si vede... ma sul pc dell'ufficio vengoino riprodotti solo gli ultimi 10 secondi di filmato, a ripetizione, el'indicatore del tempo indica che sto al 16mo minuto di un filmato che dura QUINDICI minuti!! Com'è possibile??? Oltretutto il filmato in realta' dura piu' di un'ora!!
-- Jumpjack --
In english
I recorded for 1 hour from cvbs input on a nilox media pro m3 device,obtaining a 1gb mpg file.
It plays fine on my home pc, but on office pc only last 10 seconds of clip are played,and timer says min 16:20 of a 15:00 clip!! Clip is actually 1 hour long!
What's going on here? Same results with different players.-- Jumpjack -- -
Try remux it(no video reconversion) with avidemux, open mpg, under video and audio choose copy, format mpg and save a new .mpg file.
You can also use the old good tmpgenc to remux, under file->tools->multiplexer and add the mpg and make new mpg.
If it fails you could try the videoredo and use the quickstream fix. -
Tried all, nothing worked. All programs see multiple 10 seconds microclips for a total amount of 15 minutes... but the REAL content of the video, visible on my home pc, is 1h video
-- Jumpjack --
No Windows Media 11 Video on new XP Pro machine
By Rorge_Retson in forum Newbie / General discussionsReplies: 9Last Post: 10th Apr 2011, 01:48 -
No sound when converting video files using Daniusoft Media Converter Pro
By cookm75 in forum Video ConversionReplies: 6Last Post: 29th Apr 2010, 07:42 -
Windows Media Player: MPG playback bar moves faster than video plays
By Grunberg in forum Newbie / General discussionsReplies: 4Last Post: 15th Sep 2009, 05:07 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Slowing down video not Audio using Ulead Media Studio Pro 8
By engert100 in forum EditingReplies: 10Last Post: 25th Oct 2007, 16:17
