I have two video sources of the same show. One of the sources has a english dub and I wanna pair that to the other source which has a 720p video stream. But since they have differing frame counts, I was wondering what was the easiest way to cut or add frames. Btw I'm on a mac
Results 1 to 9 of 9
1. Go to a PC.
2. Make sure they at least have the same framerate (convert, if need be, with Virtualdub/AVISynth)
3. Use any NLE or video processor (including AVISynth, Vdub, AE, Blender?) to load both tracks and PIP/Overlay in Side-by-side mode.
Honestly, I would skip the side by side and do a "difference" color mode overlay. With ~identical clips, you will have minor variations in the difference view (based on framerate interpolation and any resizing interpolation, maybe some color balance differences), but as soon as your clips differ in terms of editing, you will IMMEDIATELY know the difference and can accommodate by adding/subtracting frames from one of the 2 tracks.
Scott -
And I suspect that's about the easiest way to do it you're going to hear ...
Very doubtful ... I think they'd advertise that prominently for $300 ...
I'm a newbie at this and after experimenting with various softwares, I would like to ask if anyone can guide me through this process
http://documentation.apple.com/en/finalcutpro/usermanual/index.html#chapter=71%26secti...034CMP-1008853
and then follow cornucopia's method.
How do i do a side by side Picture edit
By Soixante in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2012, 09:49 -
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How to put two videos side by side
By Videographer in forum EditingReplies: 3Last Post: 12th Oct 2011, 21:57 -
Combine 2 Videos Side by Side
By bseos in forum EditingReplies: 7Last Post: 19th Jun 2011, 12:34 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 03:36
