The only thing you are accomplishing is further RUINING the clips you originally captured by
1) Not listening:
https://forum.videohelp.com/threads/347160-Good-kbps-rate?p=2170555&viewfull=1#post2170555
2) Re-encoding these clips over and over and over again. Every time you re-encode you are killing the original
"questionable" quality of your original capture(since you did not listen to my "recapture to MPEG2" and DVD can ONLY
be MPEG2" advise.
AND....all you are doing is confusing yourself even more by starting new threads with the same exact subject.
WinRAR MPEG(video file) Compression Gone Haywire
By hech54 in forum ComputerReplies: 4Last Post: 20th Mar 2012, 14:13 -
Need help with compression
By dfreeman1971 in forum Authoring (DVD)Replies: 7Last Post: 4th Jun 2010, 01:18 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 23:33 -
I am at my witts end trying to reverse MPEG-4 compression. Help!!!
By forensic in forum Video ConversionReplies: 9Last Post: 30th Apr 2008, 12:16
