i just download a mkv video with format profile level high10@l4.0, i wanted to watch it at my samsung tv with usb spot but it say video codec unsupported, so i try convert it using handbrake it end up with good result but after conversion my video size from 90mb go to 230mb
so anyone here know how to make it with same quality and same size? i tried using other tool like tsmuxer h420info to change the level but it didnt work so please anyone here who know how to this please help me and sorry for my grammar lol..
PHP Code:Format : Matroska
Format version : Version 2
File size : 92.2 MiB
Duration : 24mn 10s
Overall bit rate : 533 Kbps
Movie name : Kuroko no Basuke (Kuroko's Basketball) Ep 1 - I Am Kuroko
Encoded date : UTC 2012-04-09 11:09:11
Writing application : [url=https://www.videohelp.com/tools/MKVtoolnix]mkvmerge[/url] v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Attachment : Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High 10@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 10s
Nominal bit rate : 488 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.810 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.022
Title : H.264 Hi10P 720p Crunchyroll
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=45 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=488 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60
Language : Japanese
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 24mn 10s
Channel(s) : 2 channels
Sampling rate : 44.1 KHz / 22.05 KHz
Compression mode : Lossy
Title : 2.0 AAC
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced [url=http://www.videohelp.com/tools/Sub-Station-Alpha]Sub Station Alpha[/url]
Compression mode : Lossless
Title : Styled Subtitles (HorribleSubs)
Language : English
Default : Yes
Forced : No
Results 1 to 10 of 10
Change the bitrate(use a bitrate calculator to get exact size) or the constant quality(increase it) under the video tab in handbrake to adjust the file output size. If you are using an older version of handbrake you can set the target size in MB directly.
hi thanks for your response. i didnt know what u mean use bitrate calculator. so i target the size to 90mb but the quality was so horrible did you know what im suppose to do??
no it cant play because the avc profile level is high10@L4.0. it say video codec unsupported. i try using high@L4.0 below it work on my tv
so what i want is change the avc profile level to High@L4.0 below and i dont want increase the video size or loose the quality
here is the video mediainfo
PHP Code:General
Unique ID : 184637599129575054188609443072870140576 (0x8AE7E8796522434482A773D6176F4AA0)
Complete name : D:\MOVIE\ANIME\Kuroko_s_Basketball_-_01_[AnimeFire.ir].mkv
Format : Matroska
Duration : 24mn 10s
Video
Format : AVC
Duration : 24mn 10s
Height : 720 pixels
Color space : YUV
Bit depth : 10 bits
Language : Japanese
Default : Yes
Forced : No
Audio
Format : AAC
Codec ID : A_AAC
Duration : 24mn 10s
Title : 2.0 AAC
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Prologue
00:00:40.025 : en:OP1 (「Can Do」 by GRANRODEO)
00:02:09.987 : en:Intro
00:06:12.860 : en:I Am Kuroko (Part A)
00:11:49.030 : en:I Am Kuroko (Part B)
00:22:21.999 : en:ED1 (「Start it right away」 by Hyadain (ヒャダイン))
00:23:51.960 : en:Next Episode Preview
here the video does play on my tv
PHP Code:General
Unique ID : 239541781684661276897564951612927822384 (0xB43611ABCEE9BD97BAA51D550ABCCA30)
Complete name : D:\MOVIE\ANIME\NARUTO\NARUTO SHIPPUDEN 2007 -\NS.EasyMOOVEE_211_720p.mkv
Format : Matroska
File size : 73.7 MiB
Duration : 23mn 9s
Overall bit rate : 445 Kbps
Encoded date : UTC 2011-05-12 15:43:17
Writing application : [url=http://www.videohelp.com/tools/MKVtoolnix]mkvmerge[/url] v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 5 frames
Duration : 23mn 9s
Nominal bit rate : 404 Kbps
Height : 720 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.018
Writing library : x264 core 104 r1683 62997d6
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=404 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=17500 / vbv_bufsize=14000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Default : Yes
Forced : No
Audio
Format : AAC
Codec ID : A_AAC
Duration : 23mn 9s
Default : Yes
Forced : No
Text
Format : ASS
Default : Yes
Forced : No
Menu
00:00:00.105 : en:00:00:00.105
Hi
With FFmpeg from here ---> http://ffmpeg.zeranoe.com/builds/
Use a command like this:-
Code:ffmpeg -i filename.mkv -c:v libx264 -crf 23 -preset medium -profile high -level 31 -c:a copy -c:s copy output.mkv
No, use level 40 instead:-
Code:ffmpeg -i filename.mkv -c:v libx264 -crf 23 -preset medium -profile high -level 40 -c:a copy -c:s copy output.mkv
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 15:37 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 20:40 -
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 08:57 -
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 11:45 -
Autoguessing of AVC level
By tom.tlr in forum Video ConversionReplies: 1Last Post: 14th Dec 2010, 14:25
can teach me how to use that?? sorry im not very good on this thing
