Hi, guys,
wonder if you can help out the good general here.
For the longest time Iīve used anivideo converter do convert most video formats into a format I could edit on virtualdub.
A couple weeks ago I had a computer meltdown and had to reinstall everything..... and apparently anivideo converter was one of the casualties.
When I try to convert a video into a virtualdub-friendly format, it now only gives me these options:
- x264
- mpeg4
- xvid
... none of which are formats that virtualdub recognises, whereas just a month ago I had easily about three times more video format options.
What went wrong and how can I get all those options back?
Please help.
"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
When you play it forward, it installs windows." -
Any Video Converter Free version?
And is it same version as you used before?
Because newer versions might have removed some features so you must buy the full/pro version. -
Hi, Baldrick,
thanks for the repply, I use the latest free version from their website.
The version I had was very old (I used it for years) so maybe they did remove those features."They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
You could try an old version from https://www.videohelp.com/tools/Any-Video-Converter-Free-Version/old-versions#download like from 2.xx and see how it works.
Thanks, Baldrick.
I tried quite a few of those versions but none had the number of options my previous version had.
Really strange...."They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
Looking for a converter
By zf1223 in forum AudioReplies: 5Last Post: 28th Jan 2011, 21:03 -
converter
By buzzyy in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2010, 00:32 -
HD Converter
By Stevo1975 in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2010, 18:48 -
RM Converter
By imero in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2007, 20:44 -
vcd converter?
By that Todd guy in forum MacReplies: 9Last Post: 17th Aug 2007, 10:55
