Hello,
For my pleasure and my knowledge about this, I want to program (in C or in Java, I don't know) a little software to make the structure of a Blu Ray disk.
Not a big soft with lots of options : a little with the movies as in and a static DB menu as out.
Where can I find technical decriptions of the DB structure ? I tried Google : there are only softwares, not explanations.
Thanks !
Albiréo
Did you look at this page?
http://en.wikipedia.org/wiki/Blu-ray_Disc#Directory_and_file_structure
The footnotes give more detailed reference documents. -
Thank you for your answer !
I'll search for the contains of the clpi, mlps and other files to put in the right things... -
While BD Demystified will help a good deal, you're still going about this the wrong way.
Authored consumer titles (whether AudioCD, SACD, VCD, SVCD, DVD-Video, DVD-Audio, HD-DVD or BD) are much more complex than simple container files in a folder on a disc. They have structures within structures. And not all of it is abstracted/logical structures, some is concrete/physical structures. Meaning things often have to be in an exact order, both within files and in sector order burned on the disc.
You need a "roadmap" to find where you want to go. You also need a "guidebook/index" to help you read and understand the roadmap.
Scott -
Thank you for you answers !
I thought about analysing the DB ouput of TsMuxeR but it seems to be very hard to undestand.
I effectively need a road map or ways and a long time and long readings to get informations and begin programming.
I'll try that !
If you have more informations or readings, I'll take them !
Thanks !
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 23:41 -
BDMV structure on BD-R discs
By kurkosdr in forum Blu-ray RippingReplies: 14Last Post: 2nd Dec 2009, 20:31 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 7th Jan 2009, 00:58 -
Svcd structure
By nichok72 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Aug 2008, 17:03 -
video_RM file structure
By West3360 in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2007, 14:19
