Hey all.... here's what I want to do: my Linksys 802.4g router is on the second floor, my workshop is in the basement at the opposite end of the house. The signal will not reach my shop because I am next to the furnace & metal ductwork. I can get signal about 25 ft. away. I want to set an access point to pick up the wireless signal from the router and re-broadcast so I can pick it up at my workbench.
Ok, now the question: will THIS do that? I think it will, but I am just checking.
Just to be clear: we are talking about the AP picking up the wireless signal and re-broadcasting it wireless. There is no cabling involved in this, only wireless. Then I will use a wireless dongle plugged into a USB port on the computer I am working on to pick up the signal. Thanks.
Results 1 to 11 of 11
Under Details -> Features it lists Repeater.
Supports WDS, Supports AP/AP Client/Repeater/Bridge/Multi-Bridge mode -
Right - I understand that - what I am asking is if it will function as a totally wireless repeater. I have set many access points, but the standard method is to cable-connect router to the AP, then it broadcasts the signal wireless. What I am unclear of is will it pickup a wireless signal from the router and re-broadcast the same signal wireless? Just making sure before I order it.
The manual says it can work as a wireless repeater.
http://www.tp-link.com/resources/software/TL-WA500G_User_Guide_201003.pdf -
Comments indicate security is WEP-only in wireless repeater mode. Very inexpensive, though.
Thanks... just wanted to confirm. I really don't care if it is WEP (although that seems kind of strange) since I will only use it when I am working on someone's unit and need to check that they can access the internet before giving it back to them.
Just meant no WPA or WPA2, you could go no security at all for temporary use. It didn't say you HAD to use WEP. Sorry, didn't make that at all clear.
There are alternate firmwares for several routers, if you have any laying around, that will allow for doing this with existing hardware. -
Answer to question is yes ... very simple to setup ... proper positioning will provide the best coverage ... 5dbi output will cover a considerable area with punch.
Yeah, but what I think the OP is REALLY asking about would be a "relay". Where the only the links to the base LAN & switches, etc are ALSO wireless (in addition to the link to the end device), instead of a repeater that DOES have a wired link to the LAN.
If this is true, I don't know of any Wireless routers that can do that - all the ones I know of are "repeaters". But I could be wrong. (never researched this, no need)
Scott -
Thanks all...well, guess I will find out, it's on its way from Newegg. One of the users reviews said he set it up as a relay. We'll see. The price is good and it's getting great reviews from users, so I can always find a use for it if it won't do what I want.
How to connect my wireless headphones
By Klynt in forum AudioReplies: 5Last Post: 4th Nov 2011, 18:49 -
cannot connect to internet via router hardwired to pc yet get wireless
By ultrarunner in forum MacReplies: 17Last Post: 29th Sep 2010, 15:19 -
No Ethernet port and wireless adapter but want to connect HS Internet
By coody in forum ComputerReplies: 1Last Post: 11th Dec 2009, 14:57 -
Need new ADSL/ADSL2+ and access point
By Caple in forum ComputerReplies: 2Last Post: 3rd Dec 2007, 09:41 -
Connecting PDA to SMC wireless access point
By pchan in forum ComputerReplies: 0Last Post: 10th Sep 2007, 09:18
