How do I put a logo in to a mpg-file?
(Hope you guy's understand the question and answer)
You can do this when you encode the file.
It's the same thing as non removeable subtitles.
Specifically, you can use Avisynth to overlay a logo.
You could even overlay an anoying video image to
really piss people off.
I'm not sure you can do it without reencoding a file.I mean it in the nicest way. -
There is a simple filter to insert a logo into a video file (yes you have to re-encode) with Virtual Dub:
http://sauron.mordor.net/dgraft/mine.htmlAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
You can load the filter in VD and configure it and then frame serv to TMPG.
How to Remove Logo From MKV File
By 09norcim in forum EditingReplies: 5Last Post: 9th Mar 2018, 06:59 -
How to remove logo from an MP4 file?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2011, 06:20 -
The logo BMP file depth must be 24 bits
By BobAchgill in forum EditingReplies: 3Last Post: 14th Aug 2010, 15:28 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
