I'm still curious to know how the PS3 knows if a disc is burned faster than 4x. I've never owned a PS3, but the speed at which a disc is written isn't also written to the disc in any way is it? How would the PS3 know?
I also wonder if the advice to use ImgBurn, often given in threads here, fixes burning problems very often?
Not that I have anything against ImgBurn. I have it installed. I just use Nero 7 mostly because I've used it for years, I'm comfortable with it and it's never given me any software related burning problems I'm aware of. If I had to choose between paying for a newer version of Nero and using ImgBurn, I'd probably use ImgBurn. I'm just not too sure I remember any threads where the OP has returned to say "Hey, I can't burn using software "x", but I can burn correctly using ImgBurn". Then again. I've not been posting here all that long....
Results 31 to 38 of 38
Maybe the laser in the PS3 is somewhat weak, when it switches to DVD-Read Mode.
The 4x burning speed might make deeper, or more well-defined, pits, to compensate for that?
This is just a guess...
I haven't had the need to burn disks for my PS3, as I'm using an HTPC for any movies and shows that I don't have on BluRay, so I can't really help much on the 4x issue, sad to say.
However, I do have some older shows, burned @8x on TY DVD-R, and they playback fine in my Fat PS3 (it's one of the later ones that can't play PS2 Games).
I burned them nearly 5 years ago, way back before I even had a PS3, or a dedicated HTPC. -
Except the laser doesn't burn pits. It turns otherwise translucent dye opaque, which allows the laser to reflect off the surface beneath, or not, simulating the bumps of a normal pressed disc.
I get what you're saying though, although in theory a burner adjusts laser power according to the burning speed so the end result should be fairly similar whether the disc is burned quickly or slowly (although modern, high speed dyes are possibly optimized to be burned at faster speeds, hence many burners refusing to burn them too slowly). And no disc is burned at the same speed from start to finish. The average 16x burn might start off at 4x, then speed up as the burn progresses, not hitting maximum till right at the end.
I'm, just wondering how the PS3 knows all that (given the OP used the phrase "doesn't support" specifically)..... or whether it just won't play discs burned at faster speeds because the quality of the burn using his particular burner/disc combination isn't all the great.
In all the time I've spent (wasted) posting in various forums over the years, this is the first "PS3 only supports playback of discs burned at 4x" thread I've ever encountered.Last edited by hello_hello; 25th Jun 2012 at 19:26.
GEESH why dont you guys understand ? I tried IMGBURN and MANY OTHER BURNERS but none of them burn at 4x from my SATA DRIVE, I wasted around 5 4gigs DVD's trying to burn them at slower speed, there was this burner which restricted the writer from writing at higher speeds but when I tried to burn with it, that busted my SATA writer and I had to go and get it replaced.
BESIDES this isnt even related to what my question is, my question isnt about buying a 2nd SATA drive that doesnt do what I need, its about finding a solution to the existing problem. and my discs aint Crapola they are Verbatim, and I m from India and they are the best that you get here, If you havent noticed this Writer was able to write a crapola DVD when connected to a different machine..
I told you this is a weird problem.
I m still working on getting an XP live CD and trying to see if I can eliminate Vista from the equation. -
LOL! You do know that IMGBURN is not a DVD Burner. How difficult is it for you to buy a new IDE cable?
You do know a IDE dvd burner has to be in UDMA mode and not PIO mode. What is that LG Ide set as now in Vista? PIO or UDMA? If it's in PIO mode that's where your problem is. On my XP pc's my IDE drives can burn at 4x in IMGBURN. -
I dont know what else you call a software that burns stuff on a DISC (dvd/cd) other than a burner or a burning software ??? !!!!!
Anyways currently I set it to PIO 4 but it was set as UDMA by default. Just like my old PATA writer's default setting. -
Its a PATA DVD writer, there are 3 modes there ALL of them are set to auto PIO and UDMA, I manually set the PIO to 4 and now its back to default which is 'Auto" doesnt do an inch of difference, I still didnt get my handson a XP live CD I ll let you guys know when I do.
I can't rip with DVD shrink! I bought a new burner, ASUS, and it won't work
By arbutler2000 in forum DVD RippingReplies: 10Last Post: 30th May 2012, 17:52 -
Vista CD burner issues.
By snakeyes in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 10:05 -
try to ge VLC work with Vista ultimate
By volam in forum Software PlayingReplies: 13Last Post: 19th Jun 2009, 01:19 -
FAVC does not work in VISTA !!!
By gonwk in forum Newbie / General discussionsReplies: 7Last Post: 1st Mar 2009, 04:48 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 08:22
