    Mar 2005
    SEATTLE, WASHINGTON
    Hi Folks,
    Do anyone knows or have a firmware for Liteon LVW-1107HC1 DVD
    Recorder, that would bypass Macrovison???
    I used to have a CD of all the firmwares files for the Liteon LVW models.
    And I just recalled that I accidently threw the darn CD away in the
    garbage!!! Probably I wasn't pay any attention to the word I wote on it,
    "Liteon". I wrote it, but it was long time ago, and by accident I threw it
    away last week, and the garbage man picked it up.
    That would've been a good one to use.
    But now, since that I don't have it, I couldn't find them on Google.
    That where I found those LVW models firmwares, a few years back.
    Do anyone knows a trick on how to modify the LVW-1107HC1 by
    remote control??? Becuase you can on the Region by highlight the
    "Exit" and press number 2,9.6 and enter for the Region settings.
    I thought there might be some code numbers in the same way
    for bypassing macrovision?? To record old VHS movies that
    has Macrovision protection.
    Finding a firmware hack for LVW-1107HC1 is hard to find, or there
    isn't such thing. And beside this model DVD recorder does NOT have
    a USB port and does NOT have a DB-9 port to flash firmware into it.
    I think there's got to be a way to bypass Macorvision by using a
    remote control, if you know the code numbers?????
    The Liteon LVW-1107HC1 is a small and mediam size DVD recorder.
    It look like a portable player/recorder unit.
    Any tricks note on how to make LVW-1107HC1 Liteon DVD Recorder
    to bypass VHS Macrovision protection???
    Thanks,
    Eugene
    Eugene Cruz
