Hi I have just been doing some filming with a cannon XA10 camera and shot in 1080p I have imported into Adobe premier setting at 1080p and thats ok but what i have done is used some clips in after affects and would like to render the clips back into premier I have tried a 30 min clip and that took 27 hours. that was quick time png format
when i use the codec dvd it comes in 720 even though the original is 1080p what are the best render settings that allow the quality to be the same but a smaller file size yet still in 1080p has anyone got any ideas i am totally new to this
then end result is to produce a dvd but good quality
many thanks
It's not possible to have same quality for several reasons; the primary reason being DVD is standard definition (DVD-video is 720x480 (NTSC) ) . Your original video is 1920x1080when i use the codec dvd it comes in 720 even though the original is 1080p what are the best render settings that allow the quality to be the same but a smaller file size yet still in 1080p
https://www.videohelp.com/dvd
You can have similar quality if you make a blu-ray disc
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 10:01 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Exporting HD in Premier Pro
By videopetur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Jan 2009, 15:20 -
After Effects or Premier
By milway in forum Authoring (DVD)Replies: 6Last Post: 17th May 2008, 15:16 -
Using maya 8.5 with premier pro
By vipertongn in forum EditingReplies: 5Last Post: 8th Jul 2007, 03:29
